Go to Post Nats allows an exchange of a vast multitude of ideas from everywhere. Not only in robot design, but accents, tool storage, pit design, team spirt, clothing, many things. - Wetzel [more]
Unread 11-08-2011, 22:23
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
Advantage to six wheel drive?
Hi Chief Delphiers
I know there have been a lot of posts about six wheel/eight wheel drives over the last year or two, but I couldn't find the answer to my question: Why would anyone use six wheel drive (especially a WCD) unless there are bumps on the field? It seems to me that four wheel drive accomplishes the same thing that six wheel would.
Thanks,
Michael Groom
Team 955
Raiderbot
Unread 11-08-2011, 22:35
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Advantage to six wheel drive?
Turning ability.
In any skid-steer drive with more than two wheels, a phenomenon known as turning scrub arises. Wheels are dragged sideways as the robot rotates, creating significant frictional resistance to turning. This resistance can be large enough to completely prevent the robot from turning at all. Typically, this point is reached if the wheelbase is significantly longer than it is wide, as is the case in a typical, long orientation four wheel drive.
There are a number of ways to reduce turning scrub within a four wheel drive, none ideal. Casters, slick wheels, omniwheels, and unpowered wheels reduce tractive force, and shift the robot's pivot point. Shifting the robot's center of gravity to one end or the other can make it unstable. Wide orientation drives don't work with every robot design. Shifting wheels closer to the center of the robot makes the robot tip-prone.
Drop center 6 wheel drive takes full advantage of a robot's 38"x28" footprint, does not sacrifice traction, and reduces turning scrub. Since only four wheels ever contact the ground at once, the wheelbase at any given time is short and wide. But the presence of 6 wheels, spanning the length of the robot, gives the robot great stability.
For more on the phenomenon of turning scrub, I highly recommend this white paper: http://www.chiefdelphi.com/media/papers/1443
Unread 11-08-2011, 22:56
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach - FRC Under Development
FRC #6370 (Texas Titans)
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
I agree with the 6-wheel WCD advantage...
Is there any advantage in using live-axle vs. dead-axle in a WCD setup?
THANKS!
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- Head Coach / Founder - FRC 6370 Texas Titans < FRC and VEX teams under development - VRC 15842a >
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
Unread 11-08-2011, 23:13
Joe G.'s Avatar
AKA: Josepher
Live axles vs. Dead axles is more a matter of personal choice. There are definite pros and cons to both, and great teams have used both.
Live axles are generally easier to work with. With a hex shaft system, wheels and other components can be switched out extremely quickly, and independently, so you don't have to remove a sprocket to change the wheel. They are generally easier to build in a cantilevered setup. Live axles can be built inside of structural members, and transfer torque, allowing sprockets to be mounted further away from the wheels. This also makes live axles suitable for direct drive. Live axles also make the attachment of encoders easy.
Dead axles are less expensive and time consuming to build initially, since you don't have to broach parts, buy hubs, or deal with keyways. Axles often take the simple form of shoulder screws, further reducing their price. Dead axles can also be squeezed into tight places, since they don't need bearings at the interface between axle and structure. In fact, dead axles can double as standoffs, and serve key structural roles! See the Revolution swerve module for an example of this. Finally, some argue that dead axles allow faster acceleration, since the motor does not have to spin the mass of the axle.
Unread 11-08-2011, 23:18
THANK YOU, Joe G... that was _two_ excellent explanations... it's _appreciated_... ;-)
Unread 11-08-2011, 23:39
seriously?
Unread 11-08-2011, 23:43
Joining the 900 Meme Team
FRC #0079
seriously?
But the added mass of a sprocket doesn't matter? I'll leave it as an exercise for the reader to find out how wide the shaft must be to have the same moment of inertia as a 22 tooth aluminum sprocket.
Unread 11-08-2011, 23:48
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Another advantage to dead axles is that they can be tubes, while live axles in the .5 inch range would be very difficult to make hollow. I think a lot of people think that live axles allow for better reliability, because the forces acting on a dead axle are always in the same orientation, they are more likely to fail due to fatigue, or bend (depending on the application).
Unread 12-08-2011, 00:02
AKA: Michael Groom
Okay that makes sense. Thanks everyone!
Michael
Team 955
Raiderbot
Unread 12-08-2011, 00:19
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
To be fair, there's generally a sprocket on a live axle too....
BUT, isn't the same sprocket you mention required for either approach?
Live-axle Mass = sprocket, shaft, wheel
Dead-axle Mass = sprocket, wheel
In fact, though _both_ use bearings... the live-axle would have at least _two_ friction points... and the dead-axle would have _one_ friction point...
Unread 12-08-2011, 00:35
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Live axles also often use hubs for the wheels and sprockets, if not, they probably use heavier sprockets since now a hub must be incorporated into its design. I'm not saying that this has any significant effect on the acceleration, I'm just pointing it out.
But some designs allow for dead axles to rotate and might even facilitate it for the reason you mentioned.
Unread 12-08-2011, 00:53
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Most of these reasons are so minor as to not matter. I like dead axles, because all I need is a bolt, no hex shaft, broaching, bearings, hubs or set screws. It is much easier to assemble and repair (unless you guys have some really efficient live axle set-ups I hacmven't seen.)
Unread 12-08-2011, 01:07
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I like this thread, there are some entertaining responses.
Generally I prefer dead axle systems, since they are usually faster and easier to build (for those of us with less tooling) and leave more time to develop interesting robot mechanisms that aren't drive trains. The standard six wheel drive built from a kitbot is also great for the same reason.
Unread 12-08-2011, 08:55
Jared Russell's Avatar
Taking a year (mostly) off
In the entire history of FRC, I would be surprised if there has been a single match that was won or lost because one robot didn't have to "overcome" the inertial of a shaft where another one did. We are talking absolutely puny theoretical advantages here.
(But I have seen many, many matches won or lost because a robot did not have a reliable or well designed power transmission solution.)
