Go to Post that is one of the funniest non-photoshoped pictures of my father i have seen... - Lil' Lavery [more]
Unread 12-08-2011, 10:30
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
pic: Updated Sheet Metal Design- Swerve
Unread 12-08-2011, 10:31
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: pic: Updated Sheet Metal Design- Swerve
You probably want to put flanges on the top and bottom of the left and right side plates. It adds quite a bit of strength to the metal. Also, you could remove a bit more metal from the front of the frame.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 12-08-2011, 10:38
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
What is the thickness of the sheet metal?
The second version is much better than the first. The first design was lacking any serious strength because of the cut-out pattern. Nice first sheet metal chassis.
Unread 12-08-2011, 11:57
AKA: Mathew Simon
@Frenchie- I took your advise in addition to that of Akash and added structural flanges pretty much all over the design. I really worked on the sheet-metal, and I think it's much more practical now. Also to note, I redid a lot of the lightening patterns.
@O'Sancheski- 0.7" and thanks!
Expect an updated (photorealistic) rendering later today.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 12-08-2011, 12:07
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
The drive sprocket on the close module and on the module on the left need more chain wrap on them you need at least 90 degrees of wrap but the more the better.
Unread 12-08-2011, 12:12
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
uhh i hope its not 0.7" cause that robot would be EXTREMELY heavy... i think you mean 0.07"?
pretty cool design, i havent seen many swerve chassis designs before.
How much does it weigh??
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 12-08-2011, 12:27
AKA: Mathew Simon
Yes, 0.07" Thickness. I guess I missed a zero.
With everything shown in the image, (which does not include rivets, wires, a digital sidecar, anderson connectors, breaker, etc), it weighs in at about 47.5 lb (with battery). On an actual competing bot, there would of course be all these things in addition to pneumatics, superstructure and manipulators. This is just a functional drivebase.
Mathew Simon
CAD/Design
Unread 12-08-2011, 12:55
SenorZ's Avatar
SenorZ SenorZ is online now
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Window motors? They have a good amount of torque, but tend to move slow under load.
I shouldn't criticise. I've never designed an entire drive system
Unread 12-08-2011, 13:08
AdamHeard's Avatar
Lead Mentor
Can you post a view that is more descriptive of the internal structure?
Every DC electric motor is going to slow down under load (and proportional to load). There are some good papers in the whitepapers section that explain how motors work, it's very useful to know and takes all the guesswork out of working with them.
A number of teams have used 2/4 window motors for steering, with various amounts of reduction, with decent success.
Unread 12-08-2011, 13:59
Jared Russell's Avatar
Taking a year (mostly) off
If you both drive and steer both the left and right sides in the manner described by the picture, turning will be difficult (approaching impossible if you use high traction wheels).
Explanation here: http://www.chiefdelphi.com/media/papers/1443
