Go to Post ...too much to do... ...too little time... - Joe Johnson [more]
Unread 13-08-2011, 12:55
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
I may never use rivets again.
Have a look at these fasteners:
http://www.pemnet.com/fastening_prod..._to_sheet.html
If there is some way of inserting these without a hammer and anvil then I am totally sold (Does anyone know of such a way?)
EDIT: After some further reading I have discovered more problems, they appear to be almost impossible to remove and cannot be inserted from just one side (you need access to both). Still, they are pretty cool
Unread 13-08-2011, 13:10
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
Re: I may never use rivets again.
They can be inserted using an arbor press (if you have room to fit it in there).
Another method is to use a Rivet gun. There are special attachments to the rivet gun that let you thread into the PEM nut and pull it into the surface if should be in.
My preference is to try to use the press first and rivet gun 2nd.
Best,
Gabriel Goldman
Sr. Research Engineer, NREC
Unread 13-08-2011, 13:47
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
I didn't see any strength numbers, but i would Imagine this to be substantially weaker than a structural rivet. the thing that I really love about rivets is how fast they are, 3 people from our build crew can do the whole drive base frame in an hour, and I bet that these would take a lot longer to put in.
Unread 13-08-2011, 14:29
How would PEM hardware be weaker?
As for using PEM hardware instead of rivets, try a combination of both instead. Installing PEM nuts can add some time to the production of your parts. They are cool but check with your sheetmetal sponsor first if they'd have the time and can do it free of charge.
Unread 13-08-2011, 17:18
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach - FRC Under Development
FRC #6370 (Texas Titans)
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
Coincidentally, having just come back from Harbor Freight Tools today with $300.00 purchase of my first rivet-gun and matching compressor... I'm wondering why the search for something _superior_ to rivets?
I thought rivets were the ultimate way to go for FRC assembly... are there any drawbacks to using rivets?
THANKS!
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- Head Coach / Founder - FRC 6370 Texas Titans < FRC and VEX teams under development - VRC 15842a >
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
Unread 13-08-2011, 17:31
lemiant's Avatar
the Dreamer
AKA: Alex
THANKS!
Rivets are the bomb! But they have a definite drawback in that they protrude from the surface. For example, this means I will need to drill oversive holes in my bumper backs. Also, this makes all designs require larger clearances
Unread 13-08-2011, 18:48
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by lemiant View Post
Rivets are the bomb! But they have a definite drawback in that they protrude from the surface For example, this means I will need to drill oversive holes in my bumper backs. Also., this makes all designs require larger clearances
Countersunk head rivets don't protrude (on one side, at least). In fact, it looks like a flush-on-both-sides pop rivet is available too.
Unread 13-08-2011, 19:08
lemiant's Avatar
the Dreamer
AKA: Alex
Seriousy?!?!?!? Link please
Unread 13-08-2011, 19:46
In the link I posted above, scroll down a bit for the flush-on-both-sides countersunk blind rivets. (Or go here.)
Unread 13-08-2011, 19:56
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
These only work if you can pinch the hardware on both sides and you have enough room from the edge to center line of the piece of hardware. Pop rivets work great with a pneumatic rivet gun. A manual rivet gun works in a pinch for a small aluminum rivet but is hard to exert enough force to install a large stainless steel rivet.
Also keep in mine you can use self threading screws for parts that may need to be remove occasionally or go with a clinching pem nut and a screw for parts that need high holding strength and needs to be reusable/removable.
On parts that need to be located then put in place take a look at slot and tabbing or a process called half shear.
Use the correct process to joins the parts according to function. Some joining processes are rivets, screws, bolts and nuts, double back tape, spot welding, arc welding, soldering.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
