Go to Post What is it about inefficient design and operation that either pushes the envelope or deserves to be awarded? - Madison [more]
Unread 13-08-2011, 18:12
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Live Axle how to
Hello everyone,
Our team has always used the kitbot drivetrain, and therfore has no experience with live axles on a drivetrain. I want to try and CAD a design to present to my team leaders, who have expressed a desire to change from the kitbot drivetrain. However, I can't figure out what parts to use...
I have heard that a hex axle is usually better than a rounded one, mainly due to the complexity of securing something to a round shaft. However, I can't figure out what parts I absolutely need or where to get them. (besides AndyMark)
Is far as I know, the kitbot had only one bearing to a wheel, and that was just pressed in. How should I attach bearings to the structural part of the drivetrain?*
What hardware should I used to attach wheels and sprokets to an axle?*
If our team decides to use a version of the design for the season, then will posting it on CD count as "open sourcing" it?
What are your opinions about direct drive for the center wheel (6wd) vs. linking it with a chain?
Is there anythign you wish you had known before making a live axle drive system?
*pictures would also be apreciated
Thanks in advance for answering a rookie's questions.
Unread 13-08-2011, 18:42
Re: Live Axle how to
You guys are from Chandler, AZ... I would suggest a weekend road trip to Kingman, AZ. FRC 60 is one of the originators of the West Coast Drive. That was 7 years ago.
For a few answers: The hex axle is more common, but not for the reason you say. It's for reduction of stress when transferring power. You can use a round shaft, but you'll need some form of keyway; keyways like to act as stress concentrators. That can be pretty bad for the axle, maybe not immediately, and maybe not if your axle is properly sized, but potentially after an event, or during one, say during finals matches...
The Kitbot has 2 bearings per wheel, IIRC. If you only have one, there can be a bit of a problem. Typically, bearings are pressed in.
Hardware: clips on the end of the shaft, setscrews, it varies by design.
Unread 13-08-2011, 18:52
robodude03's Avatar
robodude03 robodude03 is offline
AKA: Rene Haro
FRC #1538 (The Holy Cows)
Team Role: Tactician
robodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond repute
Originally Posted by daniel_dsouza View Post
Hello everyone,
Have you taken a look at the kitbot on steroids presentation by 1114? You can do a lot with the standard kitbot drivetrain without having to go with a complete new setup. However, if you are looking to move to a new system, look into contacting a local veteran team as EricH has suggested.
Team 1538 - The Holy Cows
2015 Championships - Quality Award sponsored by Motorola
2014 Championships - Media and Technology Innovation Award
2013 Championships - Chairmain's Award Winner and Newton Finalists w/ 217 & 1986
2013 to Present - 1538 Mentor (Digital Media/Strategy)
2004 to 2012 - 399 Mentor/Coach
2000 to 2004 - 399 Driver
Unread 14-08-2011, 00:49
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
There are some off-the-shelf chassis systems with both live and dead axles....Perhaps these will help you understand how to best design your own chassis.
221 Robotic Systems
Andymark
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
