Originally Posted by squirrel
There are different ways of doing it, the Corvette used Ujoints at both ends of the axle shaft, so it isn't really a swing axle like the early VW. The axle and control arm make a parallel arm setup, so the camber doesn't change dramatically like on the early bug
but Corvette is using that strange leaf spring setup....
And this drive train could improve traction by using a sealed diff, and using silicone diff fluid to prevent the module from "diffing out"
A limited slip diff is normally all mechanical, and uses helical gears to prevent "diffing out" (but there are others that operate on clutches or springs)
a traditional limited slip setup would be VERY costly for this size (the gears would be expensive), but silicone would be a great option....
Many small differentials are easily available from any rc car shop or ebay
Cool idea!
