Go to Post You earn what you work for. - Akash Rastogi [more]
Unread 15-08-2011, 12:12
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: [FTC]: What should I know about CAD (via Pro/E) for FTC?
Originally Posted by Techhexium View Post
Thanks everyone. It would be good for me to learn more than just assembly, I find that I may need to modify structural objects in Pro/E because teams will have to bend TETRIX parts, and not every part in the FTC Kits (Legos and TETRIX metal) is available in a 3D model. (I won't need to make them from scratch fortunately because some FTC teams like 2848 have released their CAD Library)
I may be missing the point, but I'm not seeing the logic here. Wouldn't it be more helpful to know how to make parts from scratch then how to modify them? I'm sure it varies which way is easier, but for most simple parts it will be easier to make from scratch. As far as time needed, the modifying may be quicker but making parts from scratch is much easier to learn to do. I might be completely wrong, but I think your looking at it the wrong way this time.
Jason
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 16-08-2011, 18:44
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
There's no real difference in the learning aspect. If you learn how to make them, you've also learned how to modify them.
In our case, we modified some, and some we re-made. Some parts we made into families (so they could be replaced without doing a ton of work), some parts we learned about flexibility (shortening or adjusting dimensions of individual pieces in an assembly).
By the way, some of the parts in the standard library have the wrong dimensions (just slightly wrong, but too many "almost's" and it becomes a "not quite") -- I'd recommend that you watch closely for that as you look at mod'ing and creating.
As Tecchhexium mentioned, our CAD library of the parts that we re-built is located at: http://technoguards.org/CAD_Library
