Go to Post Not only does Dave like to post hints about the the new game...but now he's starting to post hints about the activities of the Mars rover. Does it ever stop?! - Alexa Stott [more]
Unread 15-08-2011, 13:16
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
pic: Latest Iteration of Swerve Module
Unread 15-08-2011, 13:17
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: Latest Iteration of Swerve Module
What kind of bearing/bushing are you using in that 2x1?
Unread 15-08-2011, 13:40
AdamHeard's Avatar
Lead Mentor
Same question.
can you post a section view of your entire bearing/shaft stackup. Drive and steering.
Unread 15-08-2011, 14:48
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Are you going with key/hex shafts?
Unread 15-08-2011, 14:51
AKA: Mathew Simon
I'm using a basic flanged bushing (Brass, I think).
Same question.
I'm going on vacation tonight, and will be away for the next two weeks, so I don't promise any new views any time soon, but I'll get one up ASAP.
Keyed shafts (.375", 3/8").
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 15-08-2011, 15:41
AKA: Mathew Simon
Okay. I did a drawing with the front and back plates suppressed. I may end up making a rendering as well.
Mathew Simon
CAD/Design
Unread 15-08-2011, 15:47
AKA: Mathew Simon
And, a rendering.
Mathew Simon
CAD/Design
Unread 15-08-2011, 16:46
AdamHeard's Avatar
Lead Mentor
Are there two bearings supporting the driveshaft?
Unread 15-08-2011, 16:52
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
What is the white/silvery thing between the module and the 2x1? Is it bolted to the module? If not, what do those 3 bolt-like things do?
EDIT: Oh, that attaches it to the pulley. In that case, what are you using to support the axial (thrust) loads?
Unread 15-08-2011, 18:21
AKA: Mathew Simon
3 bearings are supporting the drive shaft. There are two press-fit roller bearings in the lathe-turned hub which you can see holding the timing-belt pulley in addition to a single ball bearing press-fit into the actual structure.
Mathew Simon
CAD/Design
