Go to Post Your robot is trying to talk to you, all you have to do is listen. - Al Skierkiewicz [more]
Unread 15-08-2011, 13:16
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
pic: Latest Iteration of Swerve Module
Unread 15-08-2011, 13:17
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: Latest Iteration of Swerve Module
What kind of bearing/bushing are you using in that 2x1?
Unread 15-08-2011, 13:40
AdamHeard's Avatar
Lead Mentor
Same question.
can you post a section view of your entire bearing/shaft stackup. Drive and steering.
Unread 15-08-2011, 14:48
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Are you going with key/hex shafts?
Unread 15-08-2011, 14:51
AKA: Mathew Simon
I'm using a basic flanged bushing (Brass, I think).
Same question.
I'm going on vacation tonight, and will be away for the next two weeks, so I don't promise any new views any time soon, but I'll get one up ASAP.
Keyed shafts (.375", 3/8").
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 15-08-2011, 15:41
AKA: Mathew Simon
Okay. I did a drawing with the front and back plates suppressed. I may end up making a rendering as well.
Mathew Simon
CAD/Design
Unread 15-08-2011, 15:47
AKA: Mathew Simon
And, a rendering.
Mathew Simon
CAD/Design
Unread 15-08-2011, 16:46
AdamHeard's Avatar
Lead Mentor
Are there two bearings supporting the driveshaft?
Unread 15-08-2011, 16:52
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
What is the white/silvery thing between the module and the 2x1? Is it bolted to the module? If not, what do those 3 bolt-like things do?
EDIT: Oh, that attaches it to the pulley. In that case, what are you using to support the axial (thrust) loads?
Unread 15-08-2011, 18:21
AKA: Mathew Simon
3 bearings are supporting the drive shaft. There are two press-fit roller bearings in the lathe-turned hub which you can see holding the timing-belt pulley in addition to a single ball bearing press-fit into the actual structure.
Mathew Simon
CAD/Design
