#10
Re: pic: Latest Iteration of Swerve Module
3 bearings are supporting the drive shaft. There are two press-fit roller bearings in the lathe-turned hub which you can see holding the timing-belt pulley in addition to a single ball bearing press-fit into the actual structure.
