Go to Post I never use set screws to transfer torque. Something about evil spirits or whatever. - Mark Sheridan [more]
Unread 16-08-2011, 03:06
rthinman rthinman is offline
AKA: Rod Hinman
FRC #3881 (WHEAbots)
rthinman is an unknown quantity at this point
Eclipse library build errors
Hello,
I installed Eclipse (3.7 Indigo) on our Windows 7 development computer. I think I was able to install the FRC Eclipse plug-in on the second try (first try I forgot to check the box and it didn't install everything). So now I have the help files, I can create a sample project, etc. I pointed the plug-in to the JRE that corresponds to the JDK (version 6 update 26) I loaded beforehand, and that is the default. I put our team number into the preferences page for FRC.
But, I noticed after putting in the team number that there were errors in the console window, something about not building. Similarly, when I open an example project, errors show up in the "problems" window, in the console, and I have errors flagged in the source (can't import the WPI library). It seems that the WPILib does not compile, thus there are no class files.
If you are interested, here is what it says in the console window, though it doesn't tell me much about why the build failed.
-do-compile:
    [mkdir] Created dir: C:\eclipse\plugins\edu.wpi.first.javadev.sunspotfrcsdk_1.0.6.6\sunspotfrcsdk\lib\WPILibJ\build
    [javac] Compiling 126 source files to C:\eclipse\plugins\edu.wpi.first.javadev.sunspotfrcsdk_1.0.6.6\sunspotfrcsdk\lib\WPILibJ\build
BUILD FAILED
C:\eclipse\plugins\edu.wpi.first.javadev.sunspotfrcsdk_1.0.6.6\sunspotfrcsdk\install.xml:169: The following error occurred while executing this line:
C:\eclipse\plugins\edu.wpi.first.javadev.sunspotfrcsdk_1.0.6.6\sunspotfrcsdk\lib\WPILibJ\build.xml:43: The following error occurred while executing this line:
C:\eclipse\plugins\edu.wpi.first.javadev.sunspotfrcsdk_1.0.6.6\sunspotfrcsdk\ant\compile.xml:48: Error running javac.exe compiler
Any ideas about what has gone wrong, and how to fix it? It is going to be difficult to code without the class files. Thanks in advance.
Rod
Unread 16-08-2011, 03:24
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Eclipse library build errors
Originally Posted by rthinman View Post
It looks like it can't find the java compiler (javac.exe).
Do you have the java JDK installed (not just the runtime? (JRE))?
Do you have your Java installation in your %PATH% system variable?
If those are configured properly, then I don't know.
That is a very un-specific error, though it is likely not a syntax error due to there not being a line number in a .java file.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 16-08-2011, 15:32
sakekasi sakekasi is offline
AKA: Saketh Kasibatla
FRC #1160 (Firebird Robotics)
sakekasi is an unknown quantity at this point
Send a message via AIM to sakekasi
got to Window --> preferences --> Java --> Installed JREs and add your jdk there.
Unread 18-08-2011, 23:41
AKA: Rod Hinman
Success!
I already had the JDK installed on the PC, I had already added its JRE to Eclipse's preferences.
The critical piece was the PATH variable. Thanks!
Unread 24-08-2011, 22:29
nealpatel nealpatel is offline
FRC #1777
nealpatel is an unknown quantity at this point
What do you mean by %PATH% variable? I'm having the same issue and I do have the JDK installed.
EDIT: Never mind, Eclipse was pointing to JRE instead of the JDK, build works fine now!
By any chance, could anyone help with with Eclipse showing "The import edu cannot be resolved" when making new FRC Simple Project. I installed http://first.wpi.edu/FRC/java/eclipse/update/stable/ and followed http://grantgumina.boldlygoingnowhere.org/blog/?p=61
Any help would be appreciated!
Neal Patel
Team 1777
Shawnee Mission West
Viking Robotics
e-mail: neal.patel11@yahoo.com
