Go to Post It is better to err on the side of caution than to put yourself in a position to have a referee or judge make a call against you. Build smart! - Sean Schuff [more]
  #31   Spotlight this post!
Unread 12-08-2011, 16:03
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Advantage to six wheel drive?
Originally Posted by lemiant View Post
Haha, I tried, but without knowing the dimension of the gear itself, I'm pretty much out of luck
Thats also pretty easy to find. Open a cad model or look at the martin gears website. They have a pdf of physical dimensions for 20DP gears.
-RC
R.C.
MadTown Robotics Team 1323
  #32   Spotlight this post!
Unread 12-08-2011, 16:05
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach
VRC #15842 (Texas Titans)
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
Originally Posted by Jared341 View Post
Regardless of axle setup, it is strongly advised to have two support points (bearings) to fully support the "beam". Whether they are in the wheel (notice all AM wheels take two coaxial ball bearings) or in the frame (even cantilevered WCDs have two bearings per axle)...doesn't matter. You don't want to put radial loads onto a single ball bearing.
GOOD CATCH, Jared! Rookie mistake on my part...
So, I'll restate my thesis:
Live-axle Mass = sprocket, hub(s), shaft, wheel, mounting screws
Dead-axle Mass = sprocket, wheel, mounting screws
BOTH approaches use at least two bearings... the Live-axle would have at least _two_ friction points at each end of the shaft... and the Dead-axle would also have _two_ friction points built into the center of the wheel from the two separate bearings residing in the center wheel hub-area...
The mechanics of the Live-axle setup causes more friction/resistance at the bearings because of the angular pressures caused by the shaft pivoting inside the bearings as the pressures on the attached wheel (at far end of the shaft) change... times that resistance by six wheels...
I KNOW these are _minute_ differences (or, are they?)... but, it's fun to think this through...
HOW am I doing so far? Not bad for a former insurance-salesman, right? ;-)
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
  #33   Spotlight this post!
Unread 12-08-2011, 16:11
AdamHeard's Avatar
Lead Mentor
Originally Posted by Michael Blake View Post
So, a better representation would be:
BOTH approaches use bearings... the Live-axle would have at least _two_ friction points... and the Dead-axle would have only _one_ friction point...
We shouldn't underestimate the friction/drag created at each bearing-point on a Live-axel setup... if you insert a shaft into one secured flange-bearing and spin with your hand and then take the same shaft and insert into two secured flange-bearings and spin with your hand, you'll notice it takes more effort to spin the shaft... now times that by six wheels...
ALSO, the mechanics of the Live-axle setup causes more friction/resistance at the bearings because of the angular pressures caused by the shaft pivoting inside the bearings as the pressures on the attached wheel (at far end of the shaft) change...
This is quite a bit off actually. You'd still have two bearings in a wheel in a dead axle system.
For a dead axle system, your axle is held by two plates, often inches apart, and any tolerance issues will make that shaft crooked and lead to extra friction on whatever is driving it.
The double bearing issue you mention for live axle has always been a nonissue for us, our bearing blocks are one piece for the bearings and use the same hole. The load from the cantilever is higher, that is true, but it's still well within the spec of the bearing. We slammed down HARD in 2010 and didn't have a single issue anywhere, and our drive was still nice and low friction at the end of the season. I'd argue that few teams had lower friction drivetrains than us.
If anyone wants to see our live axle drivetrain, check out my uploads. Our previous 5 robots are there, all using variations of the same system.
  #34   Spotlight this post!
Unread 17-08-2011, 17:48
TroyCDH's Avatar
TroyCDH TroyCDH is offline
FRC #2450 (Radierbots)
TroyCDH is on a distinguished road
Terminology Help needed???
The discussion here live axle vs. dead axle yet both options still powered wheels? I am sure I am wrong but, to me the term dead axle, lead me to believe a non-powered wheel. A simple bolt (axle) through the frame rails, with a wheel. No sprocket, chain or belt.
For example the rear wheels on a front drive car are a dead axle.
So here in FIRST does live axle = wheel fixed to the axle (power to axle), axle rotates in frame bearings--and dead axle = axle fixed to frame, yet wheel is powered?
I guess if that is true, live or dead axles could be, or not be, powered?
Thanks Troy
  #35   Spotlight this post!
Unread 17-08-2011, 17:57
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
With a dead axle, the axle does not rotate. The wheel has bearings in it that ride on the shaft and the drive sprocket is attached to the wheel.
With a live axle, the axle and wheel are connected together. The axle rotates on bearings and the drive sprocket is attached to the axle.
With the WCD setup, the wheel is cantilevered. It is very easy to maintain since you don't have to remove the drive sprocket and chain to remove the wheel.
  #36   Spotlight this post!
Unread 17-08-2011, 18:01
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Thanks Troy
In a live axle system, the wheel is attached to the axle, and whatever form of power transmission you have is attached to the axle.
In a dead axle system, the wheel is attached directly to whatever is powering it, and the axle does not necessarily have to spin with the wheel. Examples of both would be:
Live axle
http://www.chiefdelphi.com/media/photos/36934
Dead axle (from our 2011 robot)
There is a sprocket bolted directly to the wheel on the other side, and the flat head shoulder bolt does not spin.
