Go to Post This is a solemn reminder of how fast time goes by with the blink of an eye, that if you don't run to catch up with it, it will catch up with you and sweep you away. - Ken Leung [more]
Unread 21-08-2011, 10:48
l0jec l0jec is offline
l0jec has a spectacular aura aboutl0jec has a spectacular aura about
[FTC]: New Fuse Protected Motor Power Cables
Looks like there is at least one new part already available for the new season:
http://parts.ftcrobots.com/store/detail.aspx?ID=6402
Is this the end of burnt-out Tetrix motors in FTC (& FRC mini-bots)?
Unread 21-08-2011, 13:04
Chris is me's Avatar
AKA: Pinecone
Re: [FTC]: New Fuse Protected Motor Power Cables
We've been running those cables on our robot since mid January. Sadly didn't seem to help all that much.
Unread 21-08-2011, 14:31
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Us too. Only thing they were good at was power limiting the motors and going bad at the wrong time.
Unread 21-08-2011, 17:22
Techhexium Techhexium is offline
FTC #3555
Techhexium has a spectacular aura aboutTechhexium has a spectacular aura about
Those aren't really new, they been around for sale since the 2010-11 FTC Season. I don't see any new items around yet. Even the 2011 FTC Resource Kit isn't new IMO.
Unread 21-08-2011, 20:44
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I would love to have more than three gears to choose from. I would also welcome better motors. Then it might not be necessary to worry about burning them up as much.
Unread 30-08-2011, 14:40
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
More gears would be welcome, for many reasons.
Most motors will burn up if they are stalled at near full voltage. It's just how motors work. If not, they need large gear reduction just to get enough power to do anything.
I'd rather have a motor that provides the power that I need, but have to take care with it, rather than one so wimpy that it just sits there when you apply full power.
What we really need are some appropriately sized breakers that can be used to protect the motors when they get mechanically locked. Or, it would be nice to be able to rely on the control system to use the encoders without glitching and running the motors into hard stops at full power
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 02-09-2011, 21:15
alphadog0309's Avatar
alphadog0309 alphadog0309 is offline
AKA: Karan Hiremath
FTC #0110 (MFS Foxes)
alphadog0309 will become famous soon enoughalphadog0309 will become famous soon enough
I have found that using the encoders to detect if the motor isnt running when it is supposed to be running is a great way to cut off power to prevent the motor from burning out.
In psuedo code:
- recieve command to run motor
- wait 30 msec (completely arbritrary... First number i picked, it didnt shut off too soon, so i ran with it. I plan to experiment and get this number as low as possible)
- if motor is not turning after this point, shut off power to motor, play error noise on nxt.
This system doesnt work too well with geared systems with a lot of gears where the motor could still be spinning it just would not be spinning the axle needed
Perhaps a shaft encoder would let us detect if both were spinning which would be good. I was contemplating making a shaft encoder but i dont have access to a cnc mill/lathe so it wouldnt be accurate enough to use with the existing encoders. We need these to be provided by LEGO or some third party sensor company....
Karan Hiremath
FTC Team 110- MFS Foxes
Facebook: MFS Foxes
YouTube: MFS Foxes
Twitter:
@Foxes_110
Co-Captain
Head Programmer
Service Coordinator
Builder
Electrical
Unread 02-09-2011, 22:03
PhilBot's Avatar
AKA: Phil Malone
You're 100% Correct.
I've not tried doing that on a "move to position", but on our fork lift system last year, we used the encoders to detect when the lift had reached the end of it's travel (and stalled). It would also protect the lift motor if something (eg: a baton) got jammed.
This let us call the raise and lower lift functions with good safety in autonomous and teleop.
When all else fails, Software often comes to the rescue of Hardware
Phil.
ps: I'm told that the LabVIEW DC Motor Controller interface code is more robust this year, and that many of the glitch modes I reported last year have been mitigated.
It will be interesting to run some tests.
Phil Malone
