Go to Post To give credit where credits due, thanks to the GDC for this update. - Brandon Holley [more]
Unread 24-08-2011, 20:25
NickE's Avatar
NickE NickE is offline
_
Re: Simple tshirt cannons
1) PVC is not pressure rated for compressed gases. If holding compressed gasses, a PVC failure will be violent and explosive. For this reason among others, Team 254 chose metal barrels and pressure rated air tanks for Shockwave and was very happy with this choice. If you're looking for something simpler than the welded construction we used, others have had success in the past with steel pipe. If you're just looking to do 2 barrels, it probably makes sense to skip the revolving mechanism and simply have one valve for each barrel. Keep in mind that high performing and safe valves are expensive. We went with a 1" NPT MAC Valve.
2) If you already have a mobile drivebase, you could probably build a very simple cannon in ~3 weeks if you work hard depending on how much custom construction is done.
3) For all of the piping, tanks, valves, etc, you're probably looking at slightly under $1000 to build a good, safe, cannon but you'd have to price it out depending on what parts you decide to use and which you already have. If you don't already have a set of electronics and a drivebase, the price would jump significantly.
Good luck and feel free to contact our team if you have any questions. Contact info is at team254.com. Just be sure that whatever you build is completely safe so you won't put yourself or others at risk.
Unread 24-08-2011, 20:32
Andrew Lawrence
Posts: n/a
Thanks! We have all of the electronics and drive base materials, we just need a cannon. We appreciate your help, and will contact you if need be.
Unread 24-08-2011, 20:43
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
From what I can see from the Shockwave, the barrels do not use an encoder, but rather a photo sensor to orient itself. Have you guys ever thought of improving on the design to truly be a gatling t shirt launcher? Incorporate some reloading mechanism and up the RPM. But it does give me an idea of making a gatling paintball or airsoft tank...
Unread 24-08-2011, 20:54
NickE's Avatar
_
The barrel rotation is sensorless and uses a unique locking mechanism to ensure that each barrel is securely locked into place before shooting. This design eliminates the possibility of the barrels rotating as the cannon shoots. As seen in the picture below, a bearing on a piston-actuated lever fits into slots on the barrel backing plate. We are very happy with this mechanism and it has shown to be extremely reliable with no failures. We have discussed the possibility of an auto-reloading mechanism but have not done any serious work on one.
Unread 24-08-2011, 20:59
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We use two metal tanks tied together with 1" braided hose to a Metal ball valve that is manually operated (it is the safety valve). Out of the ball valve we use a 1" sprinkler valve actuated with a spike relay and then to some braided hose to a 4" PVC barrel. We operate the whole system at 60 psi and have to repressurize the tanks after 4-6 shots.
Yes, the plastic sprinkler valve is not rated for air, but it was simple and with the safety valve, it isn't held under pressure for that long. We've used the system since 2004 on 4 different drive bases. Our current drive base has articulated mecanum front and back.
Here's a quick video we did for the local tv station website...
www.vandenrobotics.com/Videos/RobotSpirit2.wmv
We can launch up to 4 cheeseburgers to the top of our stands at games.
