pic: FRC973 offseason teaser #4
Re: pic: FRC973 offseason teaser #4
I'm getting sick of all these teasers...
But seriously, I can't wait for the finished product. You better upload a .stp file of it when you are done. |
I'll be curious to hear the final robot weight and how fast it can go with this ridiculously light manipulator hardware to go along with a lightweight WCD.
Was 973 underweight before the offseason modifications? |
Has it been painted somehow? It looks more like ABS (like out of a 3d printer) than aluminum (which might not be a bad way to go...)
44" is very long.... |
We plan to get a black hard anodize with a possible teflon impregnation in it. Neither is really necessary per the math for these parts, but we're getting them anodized anyway (as in, plain color black, so my as well get hard). |
#7
I can't get over how much engineering must have gone into this in order to use all of this cool stuff in a competition robot. You guys are apparently really taking advantage of this off season to push yourselves.
I'm increasingly doubting any chance of us outworking you. ![]() |
#8
obviously a new minibot deploy, tiny gear on the motor shaft next to a rubber wheel for the pole climb. Can be awful far away
![]() (this is sarcasm) Last edited by Aren_Hill : 26-08-2011 at 16:55. |
#9
A few students and I probably spent a solid few months on it after getting back from champs.This thoroughly is the most designed system we've ever done, and so far it's really showing with the results we've had in shop. We've tried more new things than we ever have before, and have pushed weightcutting to the extreme. We've also really, really, really started utilizing watercutting in ways far beyond what we did before. Thanks for the kind words everyone. |
#10
depending on how many of these there are, maybe a double lift? one is in the up position while the other is in the down position? with all the weight savings you might have enough to do that.
#11
First thing I thought: They are putting sails on the robot.
Then I realized the material was just the backdrop ;> |
#12
wait, how do we even know if this robot is going to play logomotion?
#13
Looking forward to seeing it Adam. -RC |
#14
Rack and pinion elevator? Can't wait to see what results!
Some random team had a rack/pinion mechanism built and working this year, only it used a beefy steel rack gear from McMaster (ouch). An early concept: In the end, even after welding supports in for the mast, they couldn't stabilize the tower sufficiently to keep the system from twisting/binding in a few spots. Their forearm/claw attached to the elevator carrier proved too formidable for the system to handle. In the end, the night before ship, they removed the rack and pinion mast and changed to a four-bar system similar to what we used, adding a motorized wrist joint in the middle of the forearm pictured above. Quite a shock to see pics of one robot one day and then find something completely different the next! It was a good call - in the end, their arm functioned very well for them. We have a waterjet sponsor, so I will be very interested in seeing how this application turns out for you! Last edited by Travis Hoffman : 30-08-2011 at 11:27. |
