Go to Post Mentor to Student: "It's OK, if you mess it up you just get to do it again." - EStokely [more]
Unread 26-08-2011, 14:22
Re: pic: Shifting Module for Drivetrain Concept
Originally Posted by Kyle Love View Post
When you run a two motor set up as mentioned, one motor will be running in reverse of the other, causing an efficiency loss and one motor spinning a bit slower then the other.
?? If the motors are geared the same and are mechanically connected to the same shaft (as mentioned) they will be spinning at the same speed.
Unread 26-08-2011, 14:38
Aren Siekmeier's Avatar
on walkabout
They will absolutely be running at the same speed (at least I hope so ) but they may be at different points on their performance curves, if these curves vary based on direction. This means you aren't necessarily at the peak power of each motor (not necessarily affecting efficiency...). However, the directional bias of a CIM is certainly small enough to disregard (if it exists?).
Unread 26-08-2011, 17:00
crazyStone crazyStone is offline
Cad posessed
AKA: Derek Stone
no team (Charger Robotics)
Team Role: CAD
crazyStone has a spectacular aura aboutcrazyStone has a spectacular aura aboutcrazyStone has a spectacular aura about
I thought the same thing that they should be the same speed, I was just told by some members of my team that the difference in preformance is great enough between 2 cims that a noticeable amount of preformance is lost when they are linked together. I find that hard to believe, but thats why this has 4 seperate transmissions to appease that belief. The pros of simply using a Supershifter will be raised. Yes the motors are being coded to run at the same speed, it is merely electrical differences within the construction of the motors that will create slight variations. Thats my understanding at least. However I am much more mechanically inclined as opposed to electrical/pneumatics, so I could be totally wrong.
Unread 26-08-2011, 17:27
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
You are right. You're team is wrong. There were issues with motor going different speeds forwards and reverse back in the day, when we were using drill motors - which do have a significant bias. However that shouldn't affect your design for three reasons:
  1. CIMs do not have a measurable bias
  2. The suggestion that the motors would 'fight' is wrong. They will settle into different points on their performance curve, with one doing more work, but they are still working together
  3. Motors in the same gearbox are going the SAME direction.
Unread 27-08-2011, 01:02
on walkabout
And besides, even with separate transmissions and all, you still have both wheels on the ground that have the same constraint on them: they must spin at the same speed. The only thing separate transmissions accomplishes is the possibility of independent motion of the wheels, which would only shred your treads unless you had mechanum.
Motors in the same gearbox are USUALLY going the same direction just because of how they are usually geared together, but it is possible to have them switched, by putting them on opposite ends of a shaft or by having an even number of gears between. In fact, one widespread instance of counter-rotating motors this year was minibots. The wheels obviously had to spin at the same speeds, just in different directions (or the motors were often on different sides of the wheels, if the wheels were both on the same side).
Unread 27-08-2011, 01:04
lemiant's Avatar
the Dreamer
AKA: Alex
True, but that definitely doesn't apply to super shifters
Unread 28-08-2011, 21:03
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
AH, got my motor types wrong...whoops.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 28-08-2011, 21:13
on walkabout
I'm confused. What doesn't apply to super shifters?
Unread 28-08-2011, 22:24
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Unless your wheels are scrubbing, the motors are "fighting" each other just as much. If we assume the wheels, gears, and chain runs are all exactly the same then the motors, even if though they are in different gearboxes will be spinning the same speed, unless your robot is sliding.
Unread 28-08-2011, 23:17
lemiant's Avatar
the Dreamer
AKA: Alex
In that post I am referring to special cases that have the motors in one transmissions spinning opposite directions. They exist, but aren't really relevant because he will be using supershifters. And supershifters do spin the motors the same direction.
Unread 28-08-2011, 23:19
on walkabout
Oh, yeah, duh. Not following my own conversation... Yes that is true that my little "usually" anecdote wasn't exactly relevant. I was mostly showing that it does indeed happen fairly frequently and that it's not really a problem.
