Go to Post Seats are seats, we're all watching the same thing. - katiyeh07 [more]
Unread 28-08-2011, 16:03
crazyStone crazyStone is offline
Cad posessed
AKA: Derek Stone
no team (Charger Robotics)
Team Role: CAD
crazyStone has a spectacular aura aboutcrazyStone has a spectacular aura aboutcrazyStone has a spectacular aura about
pic: 8-chain drivetrain (white background)
Unread 28-08-2011, 16:04
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: pic: 8-chain drivetrain (white background)
Originally Posted by crazyStone View Post
Mind if I ask for the specs again and if you made any improvements, besides improving the picture?
Academic Student (Forever)
Unread 28-08-2011, 19:46
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
While we are at it...
I have a few questions because I don't understand the purpose of this sort of drive train.
Mind clarifying a few things for the curious and naive?
1. Why does 4 gearboxes give better efficiency than just two?
2. What is the purpose of the shifting wheel sets?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 28-08-2011, 19:59
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Yes... I agree. 148s system has a omni wheel in the center of the chassis where the actuate it to the floor which allows them to strafe side to side. On your chassis i don't see any omni perpendicular to the main drive wheels. So the shifting wheel sets are useless. You can get the same results with a 4wd with the fronts being IFIs and the rears just omnis.
Just my $0.02
Unread 28-08-2011, 20:05
Arjun Namineni Arjun Namineni is offline
FRC #4384
Arjun Namineni is an unknown quantity at this point
I believe 148 eventually took out their middle strafing wheel later in the season. If I recall correctly, they used the IFI traction wheels when put up against defense and used the omni wheels while trying to maneuver and move about the field.
But I too have the same question, what is the point of having four gearboxes?
Unread 28-08-2011, 20:15
Cad posessed
AKA: Derek Stone
Team Role: CAD
No improvements have been made in this render over the orginial besides the color change on the background. I didn't have time to work on lately, should be able to fix the parts so that the assembly becomes more realistic. The Ratios have not been totally finalized but they are approximenly:
Traction Wheel (High) 1:24 (Low) 1:48
Omni Wheels (High) 1:6 (Low) 1:12
Weight of each drive module : 3.5 lbs (x4)
Weight of each transmission : 4.5 lbs (x2) (<-this is a design change here)
Weight of each CIM : 2.7 lbs (x4)
Weight overall : ~35 lbs for the drivetrain + 15 lbs for the frame.
total weight is 50lbs
The shifting wheel sets gives the ability for the drive train to aquire 3 different configurations.
configuration #1: push almost anything while the tractions are down (especially in low gear).
>..... > > = traction wheel
( no rotation is available)
configuration #2: is all trick omnis down which rotates the robot around in a circle very effectively
o.....o
...r
o.....o
configuration #3 is trick omni's down in the front ( or back) and then traction down on the other side this changes the axis of rotation.
>......o
r
>......o
Those are the configurations and some of the advantages very good traction and torque coupled with 360 deg donuts at the push of a button.
Cad posessed
AKA: Derek Stone
Team Role: CAD
double posted
Unread 28-08-2011, 20:28
Cad posessed
AKA: Derek Stone
Team Role: CAD
It was something I was told by some mentors but have now had cleared up by several members of CD. They were concerned with the loss of power due to the inefficency of running 2 CIM's on the same shaft since the CIM's have very slight differences in preformance curves due to differences with wrappings and the fields within the motors themselves. They had expressed concern over loss of preformance which the reason for the 4 transmission. In addition it was CAD practice so I took the transmissions as a challange to attempt and create a 2 speed transmission cheaper and lighter than (1/2 of ) a AndyMark Supershifter. In reality the design will probably use AndyMark Supershifters because they are much easier to obtain then it is to manufacture custom gear boxes with little experince and limited time. The 4 transmissions would be useful if in the future the team used this platform and diecided to exchange the omnis for mecanum in which case 4 gearboxes would be nessecary. Those are the main reasons for the 4 transmissions.
Unread 28-08-2011, 20:57
Aren Siekmeier's Avatar
on walkabout
A fair amount of discussion has already taken place here. This is a newer render.
Unread 29-08-2011, 13:47
roboticsgoof95's Avatar
roboticsgoof95 roboticsgoof95 is offline
The Giggle-bot
AKA: Jamie Ortiz-DeLeon (giggles)
FRC #4002 (Rhombi Robotics)
Team Role: Operator
roboticsgoof95 has a spectacular aura aboutroboticsgoof95 has a spectacular aura aboutroboticsgoof95 has a spectacular aura about
What CAD software did you use?
Unread 29-08-2011, 23:29
Cad posessed
AKA: Derek Stone
Team Role: CAD
Autodesk Inventor Professional 2012
with the lovely education watermark on the printed drawings.
The rendering is just in Inventor Studio, haven't gotten around to learning maya or 3d-max enough to render the image in either of those suites.
Unread 30-08-2011, 08:17
The Giggle-bot
Team Role: Operator
Well, I must say that is pretty sweet.
