Go to Post I have gone and confused myself again. Why does this happen every time? - Jay Trzaskos [more]
Unread 29-08-2011, 10:53
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Advanced LabVIEW programming?
Originally Posted by Greg McKaskle View Post
If the subsystem needs to run when a setpoint is changed, then consider using an RT-FIFO -- a powerful realtime queue that allows you to choose when the loop should run, and allows the rest of your program to enqueue new setpoints or actions.
Greg, I have a question. How does a RT-FIFO differ from a regular Queue (found in the Synchronization palate)? It seems to me (after doing some reading about the RT-FIFO here), that the two are essentially the same thing. The only apparent difference is that an RT-FIFO would be specifically for Real-Time applications, while the other queue is for others. Can you please explain the difference between the two and when to use one over the other?
Thanks,
Phil
