Go to Post Re: New to programming, any tips? Join the mechanical team :) - IndySam [more]
Unread 27-08-2011, 01:04
Aren Siekmeier's Avatar
on walkabout
Re: pic: Drivetrain Concept
Originally Posted by Hawiian Cadder View Post
right, but their driver was able to sort of drift, which made it one of the fastest robots in turning around to place tubes.
Yeah, like a power slide.
Unread 27-08-2011, 08:29
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
If I'm not mistaken couldn't this also be a 4 speed shifter?
With the two ratios on the gearbox than then the two different ratios given on the wheel sizes and reductions (don't know if they are synced)....
Thats. Insane. I like it!
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 29-08-2011, 14:55
crazyStone crazyStone is offline
Cad posessed
AKA: Derek Stone
no team (Charger Robotics)
Team Role: CAD
crazyStone has a spectacular aura aboutcrazyStone has a spectacular aura aboutcrazyStone has a spectacular aura about
Just realized there was a mistake in the design concerning which Supershifter drove which side. A redesign is nessecary and taking place and should clear up some of the issues of the 2 transmissions. We are now attempting to link both front modules to one supershifter and both back modules to the other. Instead of the linking front and back on each side like it is now.
Unread 29-08-2011, 15:00
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
If I understand this right you're switching from this linkage:
<front>
o o
o o
to this:
<front>
o-o
o-o
If that is the case you won't be able to turn.
Unread 29-08-2011, 15:31
Cad posessed
AKA: Derek Stone
Team Role: CAD
good point which represents the reasoning behind having 4 gearboxes. You limit mobility if you restrict the ways you can turn if you link front and back together.
Unread 29-08-2011, 15:39
on walkabout
I don't get it. You obviously can't have both front wheels and both back wheels together, because both sides are always doing the same thing, and you therefore can't turn. Also, if you try to make the front wheels do something different from the back wheels, you will just shred your tread (at best).
You CAN however have each side on one gearbox, and as already stated many times, there's no reason not to. Standard tank turning is accomplished by running each side at different speeds (or even different directions).
Unread 29-08-2011, 15:50
Cad posessed
AKA: Derek Stone
Team Role: CAD
yes it can be done and its a good approach and it is our fallback, but if you want to run traction in back and omni in front you can't have different ratios because the wheel size is different whereas if the the gearboxes are seperated the speeds themselves can be altered and allow for the two different wheel sizes to work together.
Unread 29-08-2011, 20:30
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
You can accommodate different wheel sizes driven off of the same gearbox by gearing the wheels at a ratio (to each other) equivalent to the ratios of the wheel sizes. For example, if you have a 4inch and an 8 inch wheel driven off of the same gearbox, by having a 1:1 sprocket ratio between the output and the 4 inch wheel and a 2:1 ratio between the output and the 8 inch wheel they will run at the same ground speed. It is usually lighter to uses different sprockets to accommodate the wheel size difference than to use different gearboxes for the different wheels.
