| Thread Tools |
Rating:
Display Modes |
#16
Re: [FTC]: Game Hints???
Just because:
8/12 Jeff Bridges - Tron "20 years ago" - Maize Craze 8/15 N/A 8/18 Penguin -Flight(less) -Sliding - Lunacy regolith "blank sheet of paper" "the ideas will be flying" 8/22 Disc -bowl -melt "that flew into Manchester" 8/24 Apples - tennis ball-sized basket "cider donuts" 8/27 Motorcycle -Victory KingPIN "soaking up" 8/29 Sunset Traps "bowling over" I dunno - there's definitely something having to do with bowls or bowling. Last edited by normalmutant : 29-08-2011 at 15:49. |
#17
![]() On the left side of the image is a bowling pin-shaped bouy. ![]() Also, the penguin is wearing a bowler hat. I have no idea how the apples work in, however. Either the game object is a plastic bowling pin, the game's name has to do with bowling, or the game itself is a derivative of bowling. Last edited by normalmutant : 30-08-2011 at 19:14. |
#19
Since Game hints tend to be obscure, I don't think it is as simple as bowling. Maybe gutters? What else (numbers and shapes) are associated with bowling?
#20
Typically, with the actual game concept, the hints are pretty obvious. Remember last year with all the hints having to do with bridges? We had an idea, but no clear gameplay, and we were blown away when we found out about the rolling goals.
It will not be as simple as just bowling, I can tell you that, but it should be bowling-related. |
#21
The only thing so far I'm definitely paying attention to was the doughnut references. They've done that before with FVC 07' I dunno. I've been in FIRST hibernation for 3 months. but I'm awake again!
#22
I'm leaning towards shooting disks (flat torroids), and ringing them on bowling pins.
Maybe the pins will stacked at different levels (like the crab traps). King Pin has higest points. Kinda like a sideshow game. Possible game names: King Pin. Bowl me over. |
#24
Still feeling good about ring stacking.
Having an IR beacon would let you do it from a distance (maybe ![]() The "Old and New" caption was interesting..... Reference to an old game, or old tech? |
#25
#26
note some awkward language in the posts:
the next one is weird but as Nate Knauss said, its a KingPIN motorcycle... could be a stretch but who knows... Quote:
... and finally beacons on some large objects. To me the pins might work, because you can put a donut on a pin but who knows... notice the use of the word "cooler"... who knows what that might mean? just my thoughts... its all speculation though haha ![]() EDIT: "Old and New" could mean a lot of things... Recycling game pieces ie hockey pucks from face off for a Regolith hockey game.... Atlas ball/softballs from hanging around for a "bowling" game... Many different choices there.... Also... Could the record point towards a new material? Vinyl perhaps? Idk it seems to be heat deformed so that could be showing off a property of a new material idk... Vinyl could also hold a pattern so maybe we could make our own tires to work better on Regolith??? Last edited by alphadog0309 : 01-09-2011 at 18:56. |
#27
8/12
Jeff Bridges - Tron, Big Lebowski "20 years ago" - Maize Craze 8/15 N/A? 8/18 Penguin -Flight(less) -Sliding - Lunacy regolith -Cold/cool habitat -Bowling pins are penguin shaped -Bowler Hat "blank sheet of paper" "cool (and talented) people" "the ideas will be flying" 8/22 Vinyl Record -Disc -bowl(ing) -melt (ice/cold) "that flew into Manchester" 8/24 Apples -tennis ball-sized -basket "cider donuts" 8/27 Motorcycle -Victory KingPIN -Lightcycle "soaking up" 8/29 Sunset Traps buoy resembles bowling pin "bowling over" "ensure their safety" (guarding pins from opponents?) "wet and windy" "winds are light" 9/1 2 lighthouses -IR beacons -7-10 split "a bit cooler this morning" References: bowling: about 7. Some of them are a stretch, so I didn't count them. Flying: 5 (counting references to wind) Cold/cool: about 4 Tron: 3 Disc/donut: 2 Maize Craze: 2. Barely. ![]() |
#28
7-10 split sounds good...
Maybe those 2 pins have beacons on them for autonomous placement of pins and teams have to arrange pins in the bowling arrangement and you can roll a ball to knock down the other teams pins? Or shoot a flying disc to knock them down? So this game would be played like this... - each team starts with pins #7 & 10 which each have a beacon - teams have 8 pins they can try to put in the correct spots - teams can shoot down other teams pins - endgame- teams have large ball they can roll to knock down other teams pins - doughnuts = multiplier? Could be used to multiply number of pins standing by certain amount, just as yellow ball in hot shot... |
#29
Would the teams be scored by how many are left standing? It would be cool if the robots could reset their alliance's pins. That would make the game really crazy.
I wonder whether there will be a barrier between the alliances or not, like in VEX Clean Sweep, or whether the alliances will use the entire field. If it's the latter, the GDC will have to make rules against hoarding the other alliance's pins. And our team would find a loophole. And we would probably get in trouble for it. Last edited by normalmutant : 02-09-2011 at 21:45. |
#30
Yeah i think the robots should reset their own pins and there probably should be some release mechanism for the bowling ball that could be blocked.
In terms of "hoarding" there are obviously going to be a few strategy options here.... Placing pins, knocking opponents pins down, and possibly hoarding the "knockdown" objects, whatever they may be.... |
