Go to Post People can talk a big game, but unless they start working on what they talk about, nothing will get done. - Lisa Perez [more]
Unread 26-08-2011, 22:33
camper365 camper365 is offline
FRC #1599
camper365 is an unknown quantity at this point
RobotDrive for CAN?
I'm new to using Windriver, we've been using Labview for the past 3 years, and I've been playing around enough to figure out the RobotDrive interface, but I was wondering if I can get it to work with CAN Jaguars. If not, where can I go to find basic documentation on how to program a CAN Jaguar system. I've done a lot of searching for how to use C++ for the CAN, but I can't really find anything that's basic on the software level (I found plenty on how to set up the hardware, which was incredibly nice).
EDIT: I found example code at FirstForge, and it made things make sense. Because I'm at home right now and won't have access to the robot until Monday, I won't know for sure if it works, but it looks like it will (meaning it won't).
http://firstforge.wpi.edu/integratio...ystem=exsy1002
The world only has as much power over you as you let it have.
Linux: Here's the computer, just do stuff.
Unread 27-08-2011, 02:18
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: RobotDrive for CAN?
While we are on the topic of CAN, why would you need it? What are the advantages of CAN? Why not stick to the ol' PWM?
Unread 27-08-2011, 06:25
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Just a heads up, the CAN Jaguar project on FIRST Forge is deprecated I believe. CAN functionality is now built into WPILib itself. You want to use the CANJaguar class found in CANJaguar.h. It implements SpeedController, which means it can be passed into the constructor of RobotDrive.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 27-08-2011, 12:20
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
I hate to be "that" guy but, there is an entire subforum dedicated to
CAN. http://www.chiefdelphi.com/forums/fo...play.php?f=185
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 28-08-2011, 22:32
Aren Siekmeier's Avatar
on walkabout
I don't know about C++, but in LabView the Open RobotDrive subroutine in WPILib is polymorphic and can either create a CANJaguar RobotDrive object or a PWM (Victor or Jaguar) RobotDrive object (or even a RobotDrive object from existing motor references). This may apply to C++ as well, having the same OO characteristics.
Unread 30-08-2011, 09:19
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
The same holds for the C++ WPIlib.
Why a CAN bus? Closed Minor Loop control and simplified wiring layout
Why not? with 9 years of Victor experience and 2 years of Jaguar experience, the nod for robustness goes to the Victors for now.
We really like the CAN bus but, will most likely revert to Vic's for the 2012 competition season. We'll see ...
Eric
Don't PANIC!
S. P. A. M.
