Re: Belt Driven instead of Chain driven
Belts require a much more precise frame, so I would never use belts with the kit frame. belts take up a lot more space than chain as well.
They do?
Belts are workable just like chain but they require a bit more thought and design than a standard 35 chain drivetrain to work. You also have to be careful with belt reductions to make sure you're not putting too much stress on the pulley teeth. |
We've used belts for our encoders, but so far never for our drive train, or even for our arm apparatuses.
My team hasn't done a belt drive, but there are some products out there that could simplify doing one. AndyMark sells a v belt pulley http://www.andymark.com/product-p/am-0592.htm. It was developed by team 1810. It is made in 2 pieces of plastic so that when you need to replace the belt, you just unbolt one side of the pulley and slip the belt on. And being plastic they are light, unlike the traditional pulleys. 1810 could tell you more.
There are also Link v -belts that you can shorten or lengthen yourself. You can also remove a link and thread them like you would a chain and reconnect them. Harbor Freight has some at http://www.harborfreight.com/vibrati...elt-43771.html. Grainger and IBT also have them. I haven't used these, but they look intriguing. I have no idea what kind of slippage they would have. If you want to go with the Gates Belts, they have a lot of videos to show you how at http://first.gatesprograms.com/video. My team was never organized enough to know what length we needed in time to order. I know every time I pick up the chain, I keep thinking about how wonderful it would be to shed those pounds. |
This is key. The GT2 profile can take more than twice* the load that the standard tooth profiles can take.
The belts are well documented, and after you figure out what is important, the docs are not bad. You can easily check what belt width, and tooth counts will support what loads. *It could be even bigger than this. I haven't read the gates manual recently. |
#7
The most relevant piece here is comparing XL belt to 5mm gt2, pretty much identical belts in terms of size and weight. It's amazing the tooth profile makes such a difference. |
#8
Im Working on a chassis, and want to put belts on it. Where do I find Belts/pulleys for CAD and how do i buy them?
#9
The SDP-SI catalog has lots of different pulleys of various tooth profiles, pitches, tooth counts, etc. and if you click the part number you can find a CAD download in the window that pops up. At the very least this gives you the tooth profile which you could rework into other pulley geometries (different hubs, flange/no flange, etc.).
However, usually you don't care about the actual tooth profile so you could just create part files with all the other geometry (hub diameter, length, pitch diameter, etc.) and put those in the model. Solidworks has a belt feature under Insert>>Assembly Features that allows you to route an "imaginary" belt (it just shows a line) that you can use to measure the length. I'm certain similar tools exist in Pro/E/Inventor. |
#10
I can't say we've ever done them on 2815, but my alma mater 1293 used them this year on their kit-frame drive system. Twisting issues from their arm tower caused enough issues that they took them out for the connections from their gearboxes to their rear and middle wheels; to my knowledge, the middle-to-front belt run gave them no real issues. I'll try to get someone from 1293 into this thread.
#11
Is it possible to do belt drive with a dead axle? im trying to do this because i have NO experience with live axles and want to try belts. If it is possible is there an example i can see, picture or a CAD i can see?
#12
I've seen it done, but in a superstructure. 330's 2006 robot had a series of dead-axle belt connections in its feeder system, and a dead-axle belt-chain connection in the shooter system. At least, I recall it being dead-axle.
#13
This white paper does a good job of quantifying the bending problems on a standard 2010 robot. the frame bent enough to throw #35 (i think) chain, so belts would be out of the question. http://www.chiefdelphi.com/media/papers/2398 Last edited by Hawiian Cadder : 01-09-2011 at 18:09. Reason: forgot link to white paper. |
#14
Belts require more or less the same amount of precision that 25 chain requires. |
#15
The kit frame should only be one portion of your entire robot's structure. Step back and look at the whole robot. Use the other systems to reinforce the chassis and use the chassis to reinforce the other systems. I used #25 chain on a kit frame this year with no issues. |
