Go to Post BTW - using any Lavery clue to figure anything out could be equally impossible. - Raul [more]
Unread 31-08-2011, 15:02
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Belt Driven instead of Chain driven
Im not sure if this is legal for the wheels of the robot. But ive seen arms that use belts instead of chain which frankly seems like a better and cleaner installation than nocking out segments from 100 feet of chain. so can anyone help me out and tell me if its legal to have a belt driven drive train. Also your opinion on which is better
Unread 31-08-2011, 15:06
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Belt Driven instead of Chain driven
I have never done it personnaly but im sure its legal. Just after shipping this year a team put a picture up of their drivetrain, driven by belts instead of chain.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Originally Posted by Camren View Post
Im not sure if this is legal for the wheels of the robot but ive seen arms that use belts instead of chain which frankly seems like a better and cleaner isntallation than nocking out chains for 100 feet of chain. so can anyone help me out and tell me if its legal to have a belt driven drive train.
Completely legal (per 2011 rules); don't make up rules that don't exist.
Whether or not it's better is a matter for debate. Belts need to be tensioned much more precisely, and can be a bit tricky to work with, since they can't be split like chain can. You need to plan things out ahead of time, and get exactly the size of belt you need.
Unread 31-08-2011, 15:08
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Short answer: Yes
Long Answer: If the rules don't disallow something then go ahead. In the case of most years that means you can use whatever mechanical component for whatever purpose you want, as long as you are within the weight and cost limitations (note: there are lots more restrictions on electronics and pneumatics).
Remember though, that just because it is legal does not make it a good idea, the reason most teams use chain is because they have decided it is best for them. There have been some threads comparing belts and chain. If you are interested in using belt, do some research.
Unread 31-08-2011, 15:21
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
You may want to consider reading this white paper on chains vs. belts as you contiplate about which is better for you.
Mark
Brick walls are for other people. - Randy Pausch
Unread 31-08-2011, 23:45
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Belts require a much more precise frame, so I would never use belts with the kit frame. belts take up a lot more space than chain as well.
Unread 01-09-2011, 08:18
Many teams have used belt drives in the past. They need less maintenance and are quieter. They are much more difficult in some designs to replace though. (Most belting doesn't allow you to thread one end through the drive system and then connect the ends together) Teams have been able to use toothed belts and sprockets to great advantage in the past. While the robot rules have not been released for 2012, I would not expect a change making belting illegal. Please check the rules when they are published. Be aware, that belts can inflict personal injury the same way chain can. This might require some protection of the mechanism to prevent injuring anyone who will be exposed to the mechanism, including field volunteers.
Unread 01-09-2011, 09:29
Chris is me's Avatar
AKA: Pinecone
They do?
And what about the kit frame is imprecise at all? It's not like the kit holes are randomly placed.
Indeed true, though usually belt pulleys don't need separate hubs like smaller chain sprockets do.
Belts are workable just like chain but they require a bit more thought and design than a standard 35 chain drivetrain to work. You also have to be careful with belt reductions to make sure you're not putting too much stress on the pulley teeth.
Unread 01-09-2011, 09:31
Andrew Lawrence
Posts: n/a
We've used belts for our encoders, but so far never for our drive train, or even for our arm apparatuses.
Unread 01-09-2011, 15:27
annie1939's Avatar
annie1939 annie1939 is offline
AKA: Ann Fairburn
FRC #4388 (Ridgebotics)
annie1939 has a spectacular aura aboutannie1939 has a spectacular aura aboutannie1939 has a spectacular aura about
My team hasn't done a belt drive, but there are some products out there that could simplify doing one. AndyMark sells a v belt pulley http://www.andymark.com/product-p/am-0592.htm. It was developed by team 1810. It is made in 2 pieces of plastic so that when you need to replace the belt, you just unbolt one side of the pulley and slip the belt on. And being plastic they are light, unlike the traditional pulleys. 1810 could tell you more.
There are also Link v -belts that you can shorten or lengthen yourself. You can also remove a link and thread them like you would a chain and reconnect them. Harbor Freight has some at http://www.harborfreight.com/vibrati...elt-43771.html. Grainger and IBT also have them. I haven't used these, but they look intriguing. I have no idea what kind of slippage they would have.
If you want to go with the Gates Belts, they have a lot of videos to show you how at http://first.gatesprograms.com/video. My team was never organized enough to know what length we needed in time to order.
I know every time I pick up the chain, I keep thinking about how wonderful it would be to shed those pounds.
Unread 01-09-2011, 15:37
AdamHeard's Avatar
Lead Mentor
973 recently started looking into belts, and used them on a few things recently with success. We read pretty much all the documentation Gates has to offer, the gt2 tooth profile is very nice. We won't be replacing the chains in our drive with them for various reasons, but we'll certainly use belts in various places. We LOVE the selection sdp-si has, and we also love the plastic sprockets.
Unread 01-09-2011, 17:31
... the gt2 tooth profile is very nice.
This is key. The GT2 profile can take more than twice* the load that the standard tooth profiles can take.
The belts are well documented, and after you figure out what is important, the docs are not bad. You can easily check what belt width, and tooth counts will support what loads.
*It could be even bigger than this. I haven't read the gates manual recently.
Unread 01-09-2011, 18:09
AKA: Isaak
Team Role: CAD
Originally Posted by Chris is me View Post
They do?
Belts are workable just like chain but they require a bit more thought and design than a standard 35 chain drive-train to work. You also have to be careful with belt reductions to make sure you're not putting too much stress on the pulley teeth.
My wording was not as precise as it should have been, what I meant was the kit frame has some weaknesses in that it lacks rigidity. I also have found that the kit frame doesn't tend to stay perfectly square without a substantial amount of additional support (plywood, or larger gussets) so I would choose to use chain with the kit-bot purely because the flexing might cause damage to the belts, and if the frame warps into a parallelogram, the belts will wear out at an accelerated rate.
This white paper does a good job of quantifying the bending problems on a standard 2010 robot. the frame bent enough to throw #35 (i think) chain, so belts would be out of the question.
http://www.chiefdelphi.com/media/papers/2398
Last edited by Hawiian Cadder : 01-09-2011 at 18:09. Reason: forgot link to white paper.
Unread 01-09-2011, 18:22
AKA: Pinecone
The 2010 frame was substantially different than the 2011 frame, since the axle mounts were stood off several inches (6? 8? more?) from the actual chassis. The issue that really caused the bending and flex wasn't the kitbot profile as much as the modules that wheels were mounted to. The parts flexed relative to one another and your end result is thrown chain.
Belts require more or less the same amount of precision that 25 chain requires.
Unread 02-09-2011, 11:55
kramarczyk's Avatar
Yes, it was #35 chain thrown off that chassis, but be careful not to take this one data point as a universal problem with the kit chassis.
As Chris points out this is an issue of structure. In the case of the 2010 kitobt it is a lack of triangles supporting the chain path and the open section of the wheel risers that cause the problem.
The kit frame should only be one portion of your entire robot's structure. Step back and look at the whole robot. Use the other systems to reinforce the chassis and use the chassis to reinforce the other systems.
I used #25 chain on a kit frame this year with no issues.
Mark
