Go to Post If I can make one wish, it would be having Dean and Woodie read one of these writings of mine, so I can tell them "I get it! Give me time and give me inspiration, and one day I will be ready to take over the torch." - Ken Leung [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 01-09-2011, 17:19
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Chassis-Team 772 2011 offseason
Originally Posted by Akash Rastogi View Post
Post up a higher resolution picture please. I think I see a few issues with the frame, but don't want to comment unless I can confirm with a closer look. A lighter background would be nice as well.
I uploaded another one but this one may not be better. It may have better resolution. I dont have solidworks working on the computer im on right now. I need to reinstall it. As soon as that is fixed i will upload a better image
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 01-09-2011, 17:32
Thanks, the PDF was better.
Alright so first things first, looks like you've got a solid overall design, now it just needs some adjustment.
Start by making the front and back plates outside of all the sideplates. This will allow you to make your driverail plates all symmetrical parts and you'll only need two unique parts for this frame (1. front and back, 2. driverails). After you make all the siderails just one part, you can sandwich them all between the front and back, unlike your current design.
Next up, you could add flanges to the bottom portions of the siderails for added strength instead of just on the top and sides.
After that, you'll want to make the mounting holes for all the parts so you can rivet/bolt however you see fit. If you're waterjetting or lasercutting, you don't neccessarily need to add filets to each of the trusses but you will definitely need filets for any pocketing surrounding bearing/mounting holes. So you might as well filet all the trusses.
Once you've got those things down post up an update. Looks like you're getting there.
Unread 01-09-2011, 17:54
I urge you to read through all the posts in this thread
http://www.chiefdelphi.com/media/photos/35696
That was the first sheetmetal chassis I tried to make, so the information people posted in there is very valuable, I know it helped me a ton. Since then, I've been lucky enough to learn from people like James Tonthat, Sean Cantrell, all of JVN's CAD as well as from my current employer about sheetmetal design.
Unread 01-09-2011, 18:10
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
You could also save a bunch of material by getting rid of the trapezoids at the bottom of each side plate. Move the axle holes and transmission mounts upward some; this will reduce your ground clearance and make it easier to mount bumpers in the typically legal bumper zone.
--Madison--
...down at the Ozdust!
Unread 01-09-2011, 19:34
Thanks I read through the thread. And yea it help me understand some other things.
And i have to admit i thought that was a picture of the real chassis
2013-Present
2010-2013
Unread 01-09-2011, 22:42
As you may have noticed, there are no sprockets for chain yet (mainly cause i wasnt done). but after reading a few threads regarding chain vs belts, it made me wonder, which one i should choose. I read the page about chain vs belt, but would belt be that big of an advantage for FRC teams? Should I try using belts for the prototype or stay away from them?
2013-Present
2010-2013
Unread 01-09-2011, 22:44
There's no harm in trying something new. The big advantages can be less maintenance once installed and weight savings.
Unread 01-09-2011, 22:45
Im guessing i should put them in the design first then decide from there lol
I'll update the design next week, im not home for the weekend.
2013-Present
2010-2013
Unread 03-09-2011, 17:31
I missed this post by Madison, but I totally agree with it. Unless the game requires climbing something, you can do away with the bottom trapezoids and just move everything up about an inch and a half. Something similar to this
Unread 03-09-2011, 19:18
Aren Siekmeier's Avatar
on walkabout
Belts also require quite a bit more planning ahead, but you obviously are doing that already with the sheet metal, so it wouldn't take much to design for them instead of chain.
Unread 04-09-2011, 18:20
Right now, I am redoing the design. I a=have finished the sheet metal improvements and i am starting the Belts. But I cant find where to find the belt pulleys to put on the chassis, we are sponsored by Gates so that would be preferred. Which pulley's and belts size (width) should be good for the drive train, and how big should the pulley's be, or does it even matter, if there's no change in sizes?
2013-Present
2010-2013
