Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
Unread 04-09-2011, 15:57
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Re: Broken 360 controller needs a dead zone
I have also noticed that the xbox controllers that we used (knockoffs from best buy), auto-center themselves when initialized. We experienced this at competition when we turned turned on the driver station with the controller wire wrapped around the controller, holding one of the sticks off center. Then when tele-op started, the robot drove in a perpetual circle, really irritating as it turns out. I don't know if this solves any problems, but just some extra information.
Unread 04-09-2011, 21:08
As far as I can tell, HID joysticks in general, tend to use an initial value as the "zero" offset. Initial value is defined as when the HID device is opened. In the future, if there is time, you should unplug and replug the joystick with the correct center. If the match has already started, it may also be useful to hit F1, as this will force a joystick enumeration even though the robot is enabled.
Greg McKaskle
