Re: Crab drive steering
Please define what you mean by these two terms.
Thanks. |
Monster truck steer = front and rear steering going in opposite direction similar to a monster truck.
Diamond steer = all wheels turning 45 degrees with respect to forward allowing the vehicle to drive about it's own center axis. |
Do you mean something like Figure 1? or Figure 2? or something else? |
EDIT: This is just a guess, but from what he said I think he means the type in figure 1. (Not A)
In our situation, because two wheels are linked, Ackerman angles cannot be achieved....so we're most like Figure 1. Because left and right drive are independent we do slow down the inside wheels with respect to turning angle.
A real monster truck is probably most like Figure 2. |
#7
Did you determine the relationship between the steering angle and the skid-steer compensation empirically or by analysis? |
#8
More important to me isn't that we have Quadrasteer (formerly Monster Truck)...it's that you can access tank, crab and Quadrasteer from the same steering setup. Our control scheme uses two sticks on a PS style gamepad. Tank: Left stick up/down is driver side throttle Right stick up/down is pass side throttle Quadrasteer: Left stick up/down is all wheels throttle Right stick left/right is steering Crab/swerve: Left stick up/down is all wheels throttle Right stick left/right is all wheels steer angle Each of these modes is access by holding a top or trigger button....I prefer to have it setup as momentary. |
#9
I assumed that the center of rotation of the vehicle will be halfway between the points A and B. Multiply the "outer" wheel speed by the fraction at the end of the analysis to give the "inner" wheel speed. L is the vehicle wheelbase, W is the trackwidth, and Ø is the steering angle, clockwise from straight ahead. |
