Go to Post This may very well be the weirdest Chief Delphi thread of all time... - Ginger Power [more]
Unread 05-09-2011, 18:25
AdamHeard's Avatar
Lead Mentor
Re: Hex Axle- How to
We bought our holder for $17 on amazon. Love it.
Originally Posted by compwiztobe View Post
You can use the hex shafts from AM if those dimensions work for you, or you can machine your own. A very inexpensive ($50-$100) tool that makes this extremely easy is a hex collet holder such as this. Put your stock in a lathe collet of the correct bore and clamp the collet into this holder. The holder can be clamped into the vice on a manual mill. Then run down one side of the stock with the end mill, rotate the collet holder in the vice, and repeat until you have six identical sides.
You can also buy hex rod from various metal suppliers, but I am unaware of specifics there.
Another thing you'll want to think about is the pieces that go on the shaft. Many you can get with a hex bore, but if you ever need to do it yourself, you will need a hex broach, or a sponsoring machine shop with one, since they are significantly more expensive (~$800 for rotary).
