Go to Post We should all just be humble, courteous, and act like gentlemen (or ladies) on these forums, and not fill it with yakking about who's drive train is better. - Veselin Kolev [more]
Unread 06-09-2011, 00:37
BrendanRadabaug's Avatar
BrendanRadabaug BrendanRadabaug is offline
FRC #1902 (Exploding Bacon)
BrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to behold
Re: AndyMark - NEW "Modulox" Gear Boxes
Originally Posted by Michael Blake View Post
Dan, so I think you're saying that as a second year FRC team, we could prototype and iteratively change the gear boxes using the full Modulox kits... then, when we finalize/settle design we should replace the sliding gear box plates with custom plates, but, use the inner "guts" (gears, shafts, bearings, etc.) from the Modulox kit because the "guts" are competition quality... am I correct on this?
THANK YOU for your help!
not Dan, but if you have the capability to integrate the modulox in to your robot design it can help save weight and look streamlined. but if your team does not have machining capabilities, like say using a kitbot the provided gearboxes do work well with mounting on one. we used the "guts" on our competition robot with no problems.
Bacon
