Go to Post The only tool that will work to get our robot done in time will be a prayer rug. - Rick TYler [more]
Unread 07-09-2011, 12:19
Re: pic: VEX Mecanum Wheel/Tread
Originally Posted by Chris is me View Post
This isn't a Solidworks drop and play with some settings and go render, as obviously indicated by the quality of the render. It's a 3DS Max render that obviously had quite a lot of time put into it.
Why are we bashing students for being so proud and inspired by a part design that they make a beautiful presentation of it? Yes, the render isn't as important as the CAD file, but no one was saying it was.
Oh no no no, sorry you misunderstood, I wasn't commenting about this particular render. I was directing that at Matt from 1515 because I have talked him a lot and he mentions learning how to render better quite often. The comment wasn't directed at the OP. I wasn't bashing anything.
Unread 07-09-2011, 12:58
Originally Posted by Joyride_67_1902 View Post
We might try to build the updated version of this wheel later
Is the purpose of the dual rollers to increase load-handling capability?
Did you consider instead using a single row with larger rollers, to reduce gaps and overlap ?
Unread 07-09-2011, 14:03
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Originally Posted by sanddrag View Post
Can you explain? I'm not aware of anything currently with such high clock speeds. Are we talking a networked rendering cluster or multiple cores or what?
Lots of cores threaded together, I would have to ask the owner of the computer exactly what specs of it but I know its a Dual-Hex core 2.66 Ghz Or something like that. While I only have a dual core.
The dual roller we find more efficient from experience in the past with mecanums however the challenge of the design with a dual roller is much harder than a single roller. I can assure you in the second wheel (also posted) the wheel has a perfectly round projection.
Not to take away the work you did rendering these (they are incredible; having done renders way back when in AutoCAD on a 386 computer I know there is a ton of work involved), but the thumbnail photo of the other photo has the strange effect of two little fuzzy animals with big bulgy eyes. It doesn't show in the larger photo, but now I can't look at the Image Gallery and not see them lking back at me.
That might be the work of the image converter... CD wouldn't take the original photo because it is a 40 MB file. And CD also wouldn't handle the smaller PNG file. SO I had to find a converter online since I don't have photoshop or anything on my computer to convert to a JPG file. I just looked at it and saw what you were saying.
If you are interested in the FULL quality image send me a PM because I have to track down the file and I can attempt to email it to you.
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 07-09-2011, 15:00
R1ffSurf3r R1ffSurf3r is offline
AKA: Charlie
FRC #0233 (The Pink Team)
Team Role: Driver
R1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to behold
Originally Posted by Andrew Schreiber View Post
But... I suppose this is what I get for saying that something artistic is hard to a bunch of engineery types.
to me, engineering is an art
Unread 07-09-2011, 15:06
Joining the 900 Meme Team
FRC #0079
Then you should understand how difficult other arts, such as writing and drawing, really are.
Unread 07-09-2011, 15:07
AKA: Charlie
Team Role: Driver
music for me
Unread 08-09-2011, 06:24
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
I'm glad you see it too. The illusion is only in the thumbnail; the full photo it takes some effort to see the fuzzy animals. I don't think it's the conversion that does it, just being a tiny picture, and the natural loss of detail. I copy/pasted the thumbnail into Paint Shop Pro and at triple size the left fuzzy could go either way (animal or wheel), but at 4x there was enough detail to make it a wheel first.
Thanks for the offer of the full photo, but I must decline. If I save everything I liked, even electronically, I'd fill up my hard drive pretty quickly. As it is (before computers became my storage closet) I have a basement full of stuff. I'll just keep the memory of fuzzy mecanum wheels staring back at me and this (amusing?) picture...
