Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
Unread 07-09-2011, 16:00
AdamHeard's Avatar
Lead Mentor
pic: FRC973 offseason teaser #5
Unread 07-09-2011, 16:01
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: pic: FRC973 offseason teaser #5
It's a new minibot alignment system (at least that's my guess)
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 07-09-2011, 16:12
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Could be, but they already have a ramp. Don't know you can improve on their massive lexan alignment system?
Unread 07-09-2011, 16:30
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I guess one could make it less massive while not making it too much less voluminous.
Unread 07-09-2011, 17:20
They want it massive. It lets them have a smaller margin of error. The alignment "V" on their ramp is so large so they don't have to be anywhere close to being aligned with the pole.
Unread 07-09-2011, 18:35
This is gonna be the coolest swerve in the West.
Is that bracket also going to be reinforced with welding on the frame, or is the bracket enough?
Looking good!
Unread 07-09-2011, 18:41
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Could this be a corner of a chassis?
Unread 07-09-2011, 20:04
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Looks like the corner to a chassis but the giant hole has me guessing a simple bumper mount. What are the thicknesses of the metal?
1058 PVC Pirates 2016 - xxxx
Unread 07-09-2011, 22:57
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Looking good!
Could be titanium, But that seems like a lot of machining for titanium.
Unread 07-09-2011, 23:57
AdamHeard's Avatar
Lead Mentor
It's all plain 6061 Aluminum. The tubing is 1/16" wall, and the gusset plate is 1/16" thick. Those are 3/16" rivets and this is the finished assembly, no additional welding or bolting.
Unread 08-09-2011, 00:32
Figured as much. I'm liking the no weld designs from you.
Unread 08-09-2011, 03:04
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Probably not legal, but it would be cool if this robot could deploy 2 mini-bots simultaneously.
Unread 08-09-2011, 08:59
Brandon Holley's Avatar
Am I right in assuming there is another one of these brackets on the underside of this assembly?
We've been building frames like this for the past few years now and we really like how they turn out. In terms of getting an extremely square and accurate frame, I haven't found a better way. The nice thing with this as well, is that while welding usually isn't necessary after final construction, if you do decide to weld, the frame is already jigged together for you.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 08-09-2011, 20:35
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
All the cool teams use 1/4" Rivets.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 08-09-2011, 20:50
No because that would be pointless. Lol
