Go to Post Want the TL;DR of it? Keep it simple, effective, and easy to use. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 09-09-2011, 01:08
HammadB's Avatar
HammadB HammadB is offline
FRC #0295 (Renevatio)
HammadB will become famous soon enough
How to Lighten a gearbox plate in SW
How does one go about taking gearbox plates and lightening/cheesing them ?
Unread 09-09-2011, 01:11
Re: How to Lighten a gearbox plate in SW
Do you know how to extrude cut in Solidworks?
Make the sketch you want in the plate, and extrude cut.
Unread 09-09-2011, 18:26
HammadB's Avatar
oh, okay, I thought there was some fancy method to cut but retain the essentials or something like that, nvm then. Thanks for your help!
Unread 09-09-2011, 18:38
And just to make your life easier, make sure you check the box to attach to thickness.
