Go to Post Remember, FIRST is a great opportunity that will get you ahead in the long run but don't forget about the short run either. - ChrisMcK2186 [more]
Unread 11-09-2011, 15:05
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Calling all Mechs! (Torque calculations)
Originally Posted by Jedward45 View Post
Here are some images of the assembly, hope this clears things up
It looks like you are using a spiral bevel gear as well. Like everyone is saying find a local shop or even a team that has a broach and broach the gear. it's not even a 5 minute process. Better yet buy a 1/2" or 3/8" hex broach and a press and you will be able to use it for many years to come so you won't have this problem. A pin is possible but if you don't have to use it don't.
And if you had your location listed on your profile maybe a local team could help or someone could suggest a team.
Mentor 2415
