Go to Post There are so many creative and brilliant minds out there that build wonderful inventions and machines---surely we can be equally creative and open minded ... - Tonya Scott 476 [more]
Unread 12-09-2011, 16:41
linkhyrule5 linkhyrule5 is offline
FRC #1072
linkhyrule5 is an unknown quantity at this point
CIN code - LabVIEW Stops on run
I seem to be having an issue using Code Interface Nodes on the cRIO. The C code itself has been tested within the environment, and works when running on my laptop. However, after loading code onto the robot, the program terminates during or immediately after the CIN - a breakpoint placed immediately after the node does not trigger. My guess is that there are problems importing and xporting variables - I am using a one double and one two-dimensional double array.
Thank you for your time.
Unread 12-09-2011, 16:58
Re: CIN code - LabVIEW Stops on run
Is your code compiled for vxworks on ppc?
Unread 12-09-2011, 17:53
FRC #1072
Probably not. I just followed the general CIN directions for LabVIEW. I don't know if it matters, though, since I'm running directly from my laptop for now, though it'll be something to think about for competition.
Unread 13-09-2011, 00:41
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The CIN is not appropriate for the cRIO. You should be using the Call Library node to accomplish the same thing. Use the wind river tools to compile a .out file and call it's entry-points with a call library node.
Look here and here.
-Joe
Unread 18-09-2011, 22:53
FRC #1072
Ah, I see! Thanks! (And sorry for the slow response; for some reason the email-alert failed.)
