Go to Post After all, it's not where you are but the people you're with that make it worth while. - RoboJedi75 [more]
Unread 13-09-2011, 13:20
Chris is me's Avatar
AKA: Pinecone
Re: Minimum Ground Clearance?
We ran as low as half an inch last year without issue. We could drive and turn anywhere and never got hung up. Just because your ground clearance is less than a bump doesn't mean you'll get hung up on it. Lots of teams had less than 12 inches of ground clearance in 2010
On a "flat" field, I would recommend a half inch minimum. On a field with any obstacle, I'd probably recommend raising that up a notch or two. If next year's game has obstacles, we'll probably just throw bigger wheels onto our drivetrain to make it easy.
