Go to Post I guess I'm a bit of an apple fanatic. - Austin [more]
Unread 19-06-2011, 14:51
tjump tjump is offline
None #0010
tjump is an unknown quantity at this point
Power Wheels/Fisher Price Gearbox
Hi All,
There are several threads regarding the PW/FP gearboxes, but one thing I could not find was maximum tolerance on these gearboxes before shreading. Way back in 1999 we added steel gears to the output gear as we were all shearing off the teeth of this final output stage, but what can the inner gears handle?
I ask as we are designing other robots (non-FRC) and we are looking at motor options including the new craze with brushless motors. In general, the brushless 550 motors at 12V will be screaming at 60,000+ rpms (the Mabuchi motors that come stock with the PW/FP gearboxes usually run around 15,000 rpm). At what point would higher rpm smoke these gearboxes?
An additional direction with this query: how would running lower voltages equate to robot performance (torque) if we used lower V+ (brushless motor speed is related to input voltage and running at 6 volts would cut top end rpm to 30,000 or less depending on Kv of the motors).
Anyway, we are just trying to dig deep into motor/gearbox/battery power design to understand the relationship in all of these (several posts on other robot building sites spend a great deal of time discussing higher voltages equaling better robot motor performance... i.e. 24V systems vs. 12V systems). We want to understand how to put all of this together.
I appreciate the input.
Cheers,
Timothy Jump
Unread 20-06-2011, 17:37
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Power Wheels/Fisher Price Gearbox
Cheers,
Timothy Jump
I'm not sure about the quality of the FP gearboxes, but I can answer some questions about brushless motors.
However for your torque question, that is easy. Power output of any motor is going to be: rpm X torque X a constant (changes based on units). So, half the voltage is half the rpms. When you give half the voltage, the max amperage becomes half also (Ohm's law). So, half torque. In turn, doubling voltage gives twice the power.
This can be a bonus in overall performance (velocity, kinetic energy, ect.) of the system if you can use batteries with similar capacity at 12 and 24volts because you get 4 times the power at twice the weight. However, your batteries will need to put out twice the amps and will then run out twice as fast.
When selecting a motor you will need to have some idea of what you need it to do. Power output is the real important one. You can gear it however you like, BUT more gearing will cost you more in weight. This is sometimes important.
If you are looking for applications under 8k rpms, you may consider a brushless outrunner instead of an inrunner like you mention above. They provide fewer rpms per volt, but more torque, giving similar power outputs as inrunners. And they will need less gearing.
If I may make a suggestion on motors, the Great Planes rimfire series are good quality but won't break the bank like Axi brushless motors can. Found here: http://www3.towerhobbies.com/cgi-bin/wti0093p?&C=GHG
I have heard good things about Turnigy series motors too. Not sure where they are bought though. I haven't shopped for a brushless motor in a while, but the above principles still apply (physics doesn't change).
Best of luck,
Jeff
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 14-09-2011, 03:07
bradjordan111 bradjordan111 is offline
FRC #2256
bradjordan111 is an unknown quantity at this point
thanks a lot for pretty much useful information but Does anyone have experience converting the Power Wheels basic on/off control to some sort of more sophisticated variable-speed motor controller? Can you recommend a circuit/parts? Does this improve efficiency? Does it provide dynamic braking?
Unread 14-09-2011, 11:19
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
If you are planning on using a brushless motor you wil need to buy an appropriate brushless motor controller. You cannot power it directly from a battery.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
