Go to Post #TeamFrank - Libby K [more]
Thread Tools Rating: Thread Rating: 9 votes, 4.89 average. Display Modes
  #31   Spotlight this post!
Unread 28-01-2011, 13:17
Ryan Gordon Ryan Gordon is offline
FRC #2854 (EVHS Robotics)
Ryan Gordon is an unknown quantity at this point
Re: Kinect LabView Drivers
Originally Posted by borifar View Post
Hello Ryan,
You are doing excellent work on creating Labview driver. I am programming with Labview for > 15years. Some of my interests are visual inspection in manufacturing environment. I have used a cost effective approach and utilized consumer cameras (Canon, Olympus).Over the years I have created several measurement systems capable of measuring size with ~ 6 microns resolution (system cost <$1000) . To gain accurate measurements, the distance from the object to the camera has to be known. Several tricks can be used to resolve this, but since Kinect has a measurement laser it may have a lot of promise for automation. Do you know how accurately distance can be measured with the Kinect laser?
If you need any help with Labview Image analysis - let me know. I will be glad to help.
Regards
Boris
Hi Boris,
Thank you! The accuracy is 11bits of depth and converted into a standard measurement size is approximately 10 cm off at 4 m away, and less than 2 cm off within 2.5 m. However there is a minimum distance also needed for the Kinect, roughly 18 inches. There is lots of information here on it: http://openkinect.org/wiki/Imaging_Information There is talk about Microsoft using a higher resolution IR Projector to achieve better accuracy.
I'll definitely let you know if there's any questions I have with the image analysis
Regards,
Ryan Gordon
  #32   Spotlight this post!
Unread 28-01-2011, 13:51
borifar borifar is offline
borifar is an unknown quantity at this point
Hello Ryan,
Thank you for the link- very useful info!
Could you send me your phone # and a good time to call you. I would like to discuss some specifics off line.
My E-mail: bfarber@zircoa.com
Best regards
Boris
Dr. B.Farber
Senior Scientist
Zircoa Inc.
Solon, OH
bfarber@zircoa.com
  #33   Spotlight this post!
Unread 07-02-2011, 22:08
AndrewD's Avatar
AndrewD AndrewD is offline
Programming/Electrical Mentor
AKA: Andrew Dolio
FRC #1243 (Dragons)
AndrewD is an unknown quantity at this point
Do you have a download link up for the Kinect Driver vi's?
____________________________________________
FRC Team #1243 - The Dragons
  #34   Spotlight this post!
Unread 07-02-2011, 22:38
Hi, yes: https://github.com/RyanGordon/libfre...appers/labview
Enjoy
  #35   Spotlight this post!
Unread 05-03-2011, 00:04
Hello Ryan,
Your dirver is working well, I was able to build a visual inspection system, which inspects ceramic crucibles. Resolution is very good - 0.1" depth and ~ 0.5 mm in cross sections. The great advantage that it allows to measure OD/ID, wall thickness, height and bottom support in one snapshort. I am not aware of any other system that provides this flexibility and speed.
The only issue is instability during startup, sometimes it takes several attempts to activate Kinect, turining power on and off and restarting Labview several times. Once Kinect is activated it works well and stable. If somebody is interested, I can share the results.
Are you planing to release new version with improved stability?
Regards
Boris
  #36   Spotlight this post!
Unread 06-03-2011, 02:54
Riobotics1 Riobotics1 is offline
Riobotics1 is an unknown quantity at this point
Hi Ryan and folks who are following this thread,
Just wanted to let you know I was able to take things a little further by adding a 3D point cloud with the help of your code. Thanks for making interfacing to the kinect from LabVIEW a very simple process. Check out my post at http://riobotics.blogspot.com/2011/0...int-cloud.html. Cheers!
Also check out my youtube video:
http://www.youtube.com/watch?v=7LIL_h8JEpA
To Boris,
Yes I have noticed the same issue with activating the kinect. One time when I was debugging I used highlight execution in LabVIEW to slow things down, the program almost always works this way without error. Now that the kinect is activated, I'll run it at regular speed without any problems. So maybe, add a few delays in the initialization? Just my 2 cents.
  #37   Spotlight this post!
Unread 06-03-2011, 18:50
Riobotics, that is very cool to see! I look forward to seeing what you or other people can do with this
Hello Ryan,
Regards
Boris
Hi Boris,
That's good to hear; Yes I will continue to keep my github synced as fixes become available in the OpenKinect repository. I don't believe that any of the issues you're experiencing could be the result of the LabView wrapper itself but if there's evidence to suggest otherwise I'll be happy to take a closer look at my own code
  #38   Spotlight this post!
Unread 06-03-2011, 21:11
Hello Ryan and John,
Kudos to both of you for advancing Labview interface for Kinect.
One comment regarding stability issues on start up. My experience dealing with this kind of issues on consumer camera’s interface with Labview- having a vi that just connect to Kinect and does nothing else- typically improve stability. I just found one trick to start-up Kinect - I used only get tilt state VI, so far I was able to connect and start Kinect with no problems. I agree with John, time delay on startup is very useful
Regards
Boris
  #39   Spotlight this post!
Unread 13-04-2011, 09:08
mvonstein mvonstein is offline
mvonstein is an unknown quantity at this point
Ryan-
Great work. Just got the Kinect sensor yesterday. Working on hooking it up now. My application interests are almost exactly the same as Boris.
I'd also be willing to help you if you need anything. I've been working with Labview and the vision development library for the last 4 - 5 years and have a lot of experience with "machine vision" algorithms.
Thanks,
Mike
  #40   Spotlight this post!
Unread 14-09-2011, 17:40
perfectcheerios perfectcheerios is offline
perfectcheerios is an unknown quantity at this point
sorry for bumping this but, has there been any advance on this?
  #41   Spotlight this post!
Unread 09-10-2011, 22:11
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Talking Re: Kinect LabView Drivers
http://www.youtube.com/watch?v=hlgA2nlXUF8
Check'r out, man!
Just got this from my team's lead mentor.
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
M$ Kinect controlling robots! basicxman FRC Control System 28 17-11-2010 23:33
Using Kinect to Design Your Robot JesseK General Forum 6 17-11-2010 13:03
Drivers JulieB General Forum 22 03-02-2005 13:23
drivers esellers Rules/Strategy 5 24-01-2003 08:46
