Go to Post Also, I'm tired of the "FIRST is a simulation of the real world"-- it isn't. If the real world was like FIRST, there wouldn't be any need for this organization. - cadandcookies [more]
Unread 14-09-2011, 18:11
mathgeek01 mathgeek01 is offline
C++ Ninja in Training
FRC #3397 (Robolions)
mathgeek01 is an unknown quantity at this point
Question Encoder Wiring Help?
My (third-year) team is using the fall off-season this year to learn how to use various KoP components. Right now I'm trying to figure out how to wire the KoP encoder. I looked around for directions, but I'd really appreciate an explanation easy for an electrical-systems noob to understand. Thanks!
Unread 14-09-2011, 18:18
Re: Encoder Wiring Help?
Did you watch the movie and did it help at all?
This connects to several of the Digital Sidecar digital inputs.
1. +5 VDC power -> 5v power
2. Quadrature A channel -> signal
3. Ground -> ground (-)
4. Quadrature B channel -> signal
Unread 14-09-2011, 19:10
...or the encoder can be connected directly to a Jaguar in CAN mode:
http://www.chiefdelphi.com/forums/sh...ad.php?t=86297
Unread 14-09-2011, 20:30
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
To extend on this, note that the encoder wires come without a plug or terminal that you can use to interface with a Digital Sidecar or Jaguar. 694 has, for the past few years, made our own PWM cables, so with that equipment, we crimp terminals onto the encoder wires ourselves (we prepare the encoder wires in a 1x5 housing, and then have a splitter cable that goes from the 1x5 to 2 1x3s, the standard used on the sidecar, so that if we ever use Jaguars or give one to a team that does, the encoder cable can easily interface). The alternative is to solder the encoder wires to PWM cables, although I find this to be messier and less preferable. Hansen Hobbies is a great supplier of these materials.
If you do use the latter method, note that the white/yellow wire is signal, red is power, and black/(brown I believe?) is ground.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
