Go to Post P.S. we are a rookie team.P.P.S. we really don't know what we are doing - Carter12s [more]
Unread 15-09-2011, 11:26
AdamHeard's Avatar
Lead Mentor
pic: FRC973 offseason teaser #6
Unread 15-09-2011, 11:27
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: pic: FRC973 offseason teaser #6
This looks to be the bottom of a west coast chassis. Nice second bot.
Unread 15-09-2011, 11:58
Chris is me's Avatar
AKA: Pinecone
Those rivets sure are placed funny. What could be attaching to the majority of the middle of your belly pan? Looks like a lot of cross supports... Or the structure for some kind of lift.
Unread 15-09-2011, 12:16
AdamHeard's Avatar
Lead Mentor
We actually use the rivets for attaching electronics. We try to avoid internal crossmembers on the driveframe. We really aim for less stuff.
Unread 15-09-2011, 12:25
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
It's too thick to be a standard belly pan. I'm too lazy to search atm, but I'm fairly certain I remember several WCD teams stating they use 1/8" plate as a belly pan.
There are 2 vertical black cylinders underneath it, if you look through the gussets. Additionally, the far edges of this have holes that look like they may match up with the long rack gears Adam posted a few weeks ago. Finally, the large right-angle hole on the left hand side doesn't match any common gearbox patterns for a drive train.
Are you even hanging tubes with this bot?
GitHub
Unread 15-09-2011, 13:09
This looks 1/8" to me. Standard bellypan. And yes the bot is to hang tubes, they'll be competing with it at 3 offseason events. (plus I may have some inside info )
The orange looks a little light, Adam. Or is that just because of the photo?
Unread 15-09-2011, 13:18
AdamHeard's Avatar
Lead Mentor
The orange is a tad lighter than last year. Unsure who would have tipped you off to what we're doing.
Unread 15-09-2011, 14:53
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
I can't wait to see this all completed, it's going to be an unbelievably gorgeous robot!
-Dave Powers
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 15-09-2011, 16:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Wouldn't that make replacement difficult and prone to creating metal chips in the vicinity of electronics?
Unread 15-09-2011, 16:41
AdamHeard's Avatar
Lead Mentor
The tang left below the bellypan is so small we can cut them with dykes. Hasn't been an issue for us in the past. Most of the components riveted will never be removed or replaced anyway.
We're looking at switching to variable length plastic rivets in the future to save a little more weight (they cost about the same anyway).
Unread 18-09-2011, 03:06
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Chassis to a three wheel swerve???
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
