Go to Post Wait...engineers have personalities? - Mark McLeod [more]
Unread 15-09-2011, 13:09
Re: pic: FRC973 offseason teaser #6
Originally Posted by JesseK View Post
It's too thick to be a standard belly pan. I'm too lazy to search atm, but I'm fairly certain I remember several WCD teams stating they use 1/8" plate as a belly pan.
There are 2 vertical black cylinders underneath it, if you look through the gussets. Additionally, the far edges of this have holes that look like they may match up with the long rack gears Adam posted a few weeks ago. Finally, the large right-angle hole on the left hand side doesn't match any common gearbox patterns for a drive train.
Are you even hanging tubes with this bot?
This looks 1/8" to me. Standard bellypan. And yes the bot is to hang tubes, they'll be competing with it at 3 offseason events. (plus I may have some inside info )
The orange looks a little light, Adam. Or is that just because of the photo?
Unread 15-09-2011, 13:18
AdamHeard's Avatar
Lead Mentor
The orange is a tad lighter than last year. Unsure who would have tipped you off to what we're doing.
Unread 15-09-2011, 14:53
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
I can't wait to see this all completed, it's going to be an unbelievably gorgeous robot!
-Dave Powers
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
