Go to Post If it's the loss of American lives that concerns the nation, why not campaign aggressively against smoking, or improve automobile safety? At least then, the benefits will be tangible, and substantially more significant to the well being of the locals. - Tristan Lall [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Unread 09-15-2011, 03:55 PM
lapley3539 lapley3539 is offline
AKA: Lauren Apley
FRC #3539 (Byting Bulldogs)
lapley3539 is an unknown quantity at this point
Help with Swerve Drive Programming??
Our team wants to try out swerve drive before season starts, that way we have another drive system to use for the 2012 game if needed. Any help with the coding?
Unread 09-15-2011, 04:41 PM
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: Help with Swerve Drive Programming??
Two resources: Ether's paper on omnidirectional drive trains here and to use polar coordinates while keeping things a simple as possible.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 11-08-2011, 02:40 PM
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
If it would help i could post my code for swerve drive...
Problems you may face are:
It is field centric so you need a gyro (you may be able to rewrite i can help you)
we used window motors (dont know what you plan on doing)
I will gladly help you. Im Matt from team 228 Gus robotics i have been programming for 2 1/2 years now and am getting pretty good at it.
Here is our swerve bot from 2010:
http://team228.org/media/pictures/view/6721
http://team228.org/media/pictures/view/6202
the thing that makes this robot special is the field centric controls no matter the orientation of the robot forwards is always forwards. you may want to try it,
But do let me know if you would like my help
Unread 11-10-2011, 10:07 AM
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
I apologize if I'm looking at this wrong way, but it seems rather simple from my understanding.
Servos[1-4].set(joystick.getDirectionDegrees());
Motors[1-4].set(joystick.getMagnitude+/-joystick.getTwist());
Of course you'll need to do some adjusting for the servos and a the twist, but I think that's all that needs to be done.
Unread 11-10-2011, 10:54 AM
Assuming "servos" are the steering motors, it looks like you are pointing all the wheels in the same direction. Here on CD that's usually referred to Crab drive, not swerve.
With the motors, it looks like you are trying to do skid-steer.
So, it looks like Crab Drive with skid steering.
The problem of figuring out the theoretically correct speed and steering angle for each of the 4 wheels for any given desired vehicle motion is called "inverse kinematics". The derivation of the formulas for this is interesting but not beyond the reach of high school mathematics. The formulas themselves are straightforward.
If you could make each wheel instantaneously go to its theoretically correct speed and steering angle, swerve would be simple. But there are dynamics involved. It takes time to steer the wheel and change its speed. During this transition time, the vehicle may do unexpected and/or undesired things.
So the real problem in implementing a competent swerve drive is how to control each wheel to obtain predictable operation and acceptable response to driver commands. There are threads (and technical papers) discussing this problem.
Unread 11-10-2011, 04:31 PM
FRC #1747
wow, didn't think about that. yikes, makes it so much harder than it sounds.
Thanks for info! Definitely gonna look into it now
Unread 12-30-2012, 11:25 AM
mlyhoops mlyhoops is offline
AKA: Matthew Yamamoto
FRC #1197 (TorBots)
mlyhoops is an unknown quantity at this point
Hey ProgrammerMatt, can you help my team with the swerve drive too? we really want to be able to make that kind of drive but we haven't been able to because the coding is too complicated for us. If you can help us, please email me at mlyhoops@gmail.com
Thank you!
Unread 12-31-2012, 04:29 PM
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Thank you!
You should post more details about your particular problem here. Would be nice if you could show us what you have so far too.
