Go to Post Scout so that you're not in doubt! - Mark Pettit [more]
  #31   Spotlight this post!
Unread 23-08-2011, 10:40
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Re: Worm gears
Our team used a McMaster-Carr steel and cast iron worm gear set on last year's robot arm. We used one of AndyMark's nanobox's and a CIM to drive it. This drove a bicycle sprocket and chain to another larger sprocket mounted directly to the arm. Our worm gear set alone did not backdrive and with all the reduction we had very good control and speed, plus plenty of power. The system gave us no problems at all and we didn't even give a thought to efficiency since we had more than enough torque
We did notice some severe action when going from full up to full down, so we spring loaded the arm to reduce the "slam" factor. The arm was balanced by the springs when horizontal, so we actually drove the arm both up and down from horizontal. It worked quite well, and our rookie team was able to hang more than its share of tubes.
Though the weight of the steel.cast iron gears is greater than the plastic, I think I would go with them again, particularly on a drive system. I know the plastic gears work well in the garage door application, but I want to see some data on durability in our robot applications.
Dr. Bob
  #32   Spotlight this post!
Unread 27-08-2011, 01:03
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: Worm gears
294 used a 20:1 single threaded bronze gear/steel worm combination made by Boston Gear in both 2010 (for our kicker pullback) and 2011 (for our lift winch).
In 2011 we made the mistake of going with a cast iron worm gear (for cost reasons) on our practice robot; turns out we were operating with too high of a torque for cast iron and shredded the gear; cast iron is only rated at something like 25-50% of bronze, and our practice robot telescope wasn't as smoothly operating so it put more load on the gear. We never had an issue with it on our competition robot (as it had a bronze gear).
I'll post pictures/CAD of our 2011 gearbox if anyone is interested in more details. We used two banebots into a ~4:1 pinion/spur reduction, and a 20:1 worm reduction directly driving our 4" diameter drum. Good speed and absolutely no backdrive (we notched a slot in the end of the worm shaft so a power screwdriver could be used to manually raise/lower if necessary).
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
  #33   Spotlight this post!
Unread 16-09-2011, 02:25
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: Worm gears
reported ^
Question about worm gears kajeevan General Forum 10 20-08-2008 20:39
Worm Gears chooKcha Technical Discussion 4 30-06-2007 18:12
Worm Gears FIRST JerseyKid Technical Discussion 13 18-01-2006 10:13
Looking for nylon worm gears (~64 pitch) Travis Covington Technical Discussion 3 12-03-2004 22:30
