Go to Post If you have to build the best robot to be inspired then we end up with one winning inspired team, and 999 losers. That is not the spirit of FIRST. - KenWittlief [more]
Unread 15-09-2011, 23:06
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
What encoders do you use?
Hey Chief Delphi
I have been working on some off season drivetrains, and was wondering what encoders have worked well for you? I want to be able to hook them up to the wheels to track speed.
Thanks,
Michael
Team 955
Raiderbot
Unread 15-09-2011, 23:24
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: What encoders do you use?
The KOP encoders have always worked well for us...
Unread 15-09-2011, 23:32
http://www.chiefdelphi.com/forums/sh...75&postcount=3
(links at bottom of post)
Unread 15-09-2011, 23:58
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Is the magnetic one good, for a wheel application??
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 16-09-2011, 02:31
Aren Siekmeier's Avatar
on walkabout
If you want to measure wheel speed, the KoP encoders should work fine. They attach easily to most AndyMark gearboxes. Magnetic (absolute) encoders won't be as suited to the job, since you would need to differentiate the angle measured, where as with the optical encoders you can just count.
Unread 16-09-2011, 07:57
Ah. I somehow missed that.
Install E4P US Digital Encoder onto AndyMark toughbox gearbox:
http://www.youtube.com/watch?v=4hJfzhxZwKw
Beware the encoder rate bug in the FPGA:
http://www.chiefdelphi.com/forums/sh...2&postcount=71
http://www.chiefdelphi.com/forums/sh...74&postcount=6
http://www.chiefdelphi.com/forums/sh...01&postcount=4
Unread 16-09-2011, 08:27
Gdeaver Gdeaver is offline
FRC #1640
If you want to be cheap, use a hal effect bi-polar latch. We had a situation where mounting a shaft encoder was not nice. We attached a diametrically magnetized neodymium disc magnet to the end of the cim shaft and then mounted a Melexis US4881LUA within 3/8" of the magnet giving a non-contact Tachometer. $1.30 for 10 pieces. Used a male-female PWM cable and soldered it and a pull up resistor onto the male ends. Have to switch some pins. This will not give direction like a quadrature encoder. Can be used to give counts for distance and with a little more code velocity. Use the counter VI. Cheap non contact sensing.
Unread 16-09-2011, 10:35
AKA: Michael Groom
Okay thanks everyone!
Michael
Team 955
Raiderbot
