Go to Post If Will uses the word "dope", doesn't wear a larger FIRST logo, takes up half of the St. Louis arena, if there was not enough seating in the pits, if the music was killed during finals, it was all justified tonight. - Barry Bonzack [more]
View Poll Results: Which wheels are best for a roller claw?
VEX wheels 4 11.76%
Banebots wheels 22 64.71%
Polyurethane roller blade whee;s 8 23.53%
Voters: 34. You may not vote on this poll
Unread 17-09-2011, 16:50
Andrew Lawrence
Posts: n/a
Poll: Best roller claw wheels
Which do you think is better fitted for a roller claw in terms of grippyness and strength? The 3 wheels we are looking at are standard VEX wheels, Banebots wheels, and Polyurethane Rollerblade wheels.
Unread 17-09-2011, 19:58
run the trap!!!
Team Role: Human Player
Re: Poll: Best roller claw wheels
In 2007 Team 100 used the removable neoprene LEGO wheels for our grabber.
Except the roller blade wheels, which may be too slick, all of those options should work.
-Philip J. Fry
Unread 17-09-2011, 21:04
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Team 2745 used the banebot wheels last season and liked the grip on the tubes.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 18-09-2011, 00:39
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
The best claw wheels for 2011 application, are RC Rock Crawler wheels and tires. Some of them are specifically designed for sticking and forming to anything they touch. 973, 1323, 1625, and a few other teams used them with great success. At least from 973's manipulator, you would have to fully deflate and rip the tube to shreds to remove it.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 18-09-2011, 00:50
The Banebots wheels worked pretty well for us. Nice rubber, very light, and already hex broached.
http://banebots.com/c/WHB-HS4-194
Unread 18-09-2011, 00:51
Andrew Lawrence
Posts: n/a
And where can these wheels be found?
Unread 18-09-2011, 13:22
Marc S.'s Avatar
AKA: Adversity
I believe these are the tires 973, 1323, and 1625 used. The wheels come with a 12mm hex already in them, but we put a .5" broach through them to fit easier on our claw.
Unread 18-09-2011, 14:15
Andrew Lawrence
Posts: n/a
Thanks!
Unread 18-09-2011, 15:27
Chris is me's Avatar
AKA: Pinecone
The use of memory foam in those tires seems like a really cool concept. I wonder if I could make my own with some epoxy and Tool Dip for a coating.
Unread 18-09-2011, 15:38
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
What says that you need wheels to make the best roller claws?
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 18-09-2011, 17:10
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Not this. (not the fastest, but definitely very durable, It still works to this day. It also has more than enough grip, but that was on a fabric covered ball, the tubes might not work quite as well)
http://www.chiefdelphi.com/media/photos/30681
Unread 19-09-2011, 07:21
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Ditto.
We've made many roller claws over the years starting back in 1998 and never used wheels. We've used knurled aluminum tubing on multiple occasions and Polyurethane cord or belt on others. I doubt we'd even look at using wheels.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 19-09-2011, 09:11
Brandon Holley's Avatar
We used a combination of the green banebots wheels, and urethane round belting (aka polycord) to create our roller claw.
Here's a video of it before we got everything mounted on the chassis: Team 125 Roller Claw Testing
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 19-09-2011, 12:02
Mike dennis's Avatar
Mike dennis Mike dennis is offline
SPAM (2009-2013)
FRC #1902 (Exploding Bacon)
Mike dennis is a jewel in the roughMike dennis is a jewel in the roughMike dennis is a jewel in the rough
180 spam used natural gum rubber "wheels" on our roller claw and if we touched a tube we could leave because it was just about guaranteed to come into our gripper and not go anywhere.
