Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 06-12-2002, 14:00
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
Re: Important Houston Things
Originally posted by ChrisH
At least this way weather isn't much of a factor.
Those of us coming from Grand Rapids aren't quite that lucky, but this is April, so weather usually shouldn't be an issue.
I don't think only a week apart will be a problem in transporting equipment. After all, most of the fields are shipped to a different location every week. Even with the blizzard two years ago, the West Michigan Regional went off with out a hitch. As I've said before, FIRST will work very hard to see that things go great.
West Michigan 2001
Impressions of Houston Madison Championship Event 10 15-04-2003 01:53
any one kno about Houston???? sparkyakabair General Forum 4 21-03-2003 09:34
Official Announcement: Championship Location & Date josh_johnson Championship Event 118 29-12-2002 15:36
Please help make the Nationals in Houston AWESOME ... You be the Tournament Director Natchez General Forum 42 13-12-2002 18:50
