Go to Post Karthik was never one to shy away from the spotlight (often to the chagrin of anyone within sight or earshot of him :p ). - Travis Hoffman [more]
Unread 19-09-2011, 11:45
bobl bobl is offline
FRC #0058 (The Riot Crew)
bobl will become famous soon enough
Get code from cRIO
Our team has misplaced the laptop that we use for programming and along with it a flash drive with the backups. Is there any way to read the existing code from the cRIO so we don't have to start from scratch? We program in Java.
Unread 19-09-2011, 12:10
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
Re: Get code from cRIO
Sorry there is no way to remove code from a RIO.
Unread 19-09-2011, 12:13
That is what I thought but was hopeful I was wrong. Thanks for the quick response.,
Unread 19-09-2011, 14:21
Joining the 900 Meme Team
FRC #0079
This post seems to come up every year... I strongly suggest throwing your code into a git repository (even LV code)and putting it on a free account at github or any of the other hosted SCM sites. Revision tracking AND backup all in one and it is free.
Unread 19-09-2011, 14:29
AdamHeard's Avatar
Lead Mentor
Highly recommend the same. It's amazing how many programmers don't apreciate the importance of version control.
Off topic, but if you use the two interpreted languages available, Python and Lua, you could ftp the code off
Unread 19-09-2011, 15:37
FRC #0079
True, we are operating off the assumption that the OP did not use either of those languages. If it is incorrect and you DID use one of those the process Adam described above would work.
As for more details on SCM... the thread http://www.chiefdelphi.com/forums/sh....php?p=1073528 has a small discussion on it.
I can tell you when I start a project the first command I type is "git init" depending on what I'm doing I do I then push to a remote server (github usually). Works great for hw assignments too.
Unread 19-09-2011, 19:56
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Well, if you just want to upload new code to try it out and then put the old code back on, you can just grab startup.rtexe off of it (I don't know if startup.alias is needed.)
Unread 19-09-2011, 23:16
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
Creating a zip file of the folder of your code and uploading it to a folder on your teams website is another easy way to back up your code.
bobl, though I feel for your loss having done the same thing my self, this is a great opportunity to review coding in Java before the season starts. Not that saves you any time, but it is an awesome learning experience
Unread 20-09-2011, 00:08
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Slow your horses people. If you really really really want your code (and provided its in c++ or another one of the mentioned languages) You can "Somewhat" get the code from the cRIO. You can ftp and fecth the FRC_UserProgram.out file from the /ni-rt/system/ directory. This code can be be then decompiled using a tool such as ollydebug. This technique should be reserved for times when the amount of work to recreate what ever the old coder made is greater than about 10000000000000000 hours
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 20-09-2011, 10:13
Ollydbg contains a disassembler, not a "decompiler". You can't get your original C++ code back.
Unread 20-09-2011, 10:42
It also appears to be x86 only, which won't help you with the cRIO's ppc target.
Another option would be to use ftp to upload it to your robot.
Unread 20-09-2011, 17:47
WizenedEE's Avatar
AKA: Adam
Great idea! Also, let's put a compiler and an AI on it so it'll write its own code.
