Go to Post To the ball knockers, I salute you. - Brandon Holley [more]
Unread 20-09-2011, 00:08
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: Get code from cRIO
Slow your horses people. If you really really really want your code (and provided its in c++ or another one of the mentioned languages) You can "Somewhat" get the code from the cRIO. You can ftp and fecth the FRC_UserProgram.out file from the /ni-rt/system/ directory. This code can be be then decompiled using a tool such as ollydebug. This technique should be reserved for times when the amount of work to recreate what ever the old coder made is greater than about 10000000000000000 hours
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 20-09-2011, 10:13
Ollydbg contains a disassembler, not a "decompiler". You can't get your original C++ code back.
Unread 20-09-2011, 10:42
It also appears to be x86 only, which won't help you with the cRIO's ppc target.
Originally Posted by mesamb1 View Post
Creating a zip file of the folder of your code and uploading it to a folder on your teams website is another easy way to back up your code.
Another option would be to use ftp to upload it to your robot.
Unread 20-09-2011, 17:47
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Great idea! Also, let's put a compiler and an AI on it so it'll write its own code.
