Go to Post Woodie once said he wanted to make our brains hurt. And I *don't* think he was talking about getting beaned by 198 grams of foam.... - Ken Patton [more]
Unread 20-09-2011, 00:14
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Disabling PWM outputs w/out disabling entire bot.
Originally Posted by flameout View Post
Because I'd be spending a large amount of time calibrating the joysticks in software -- it takes around 25 minutes to download new code and I'd have to "tweak" the center values several times to get it right (I could also display binary through the OI's LEDs to calibrate them, needing only 2 downloads). If a joystick's calibration changes (they're not exactly new, and I'm already noticing drift), or a joystick is replaced, I'd have to do it all over again.
That is a good idea, though; I'd just rather not calibrate them in software.
Thanks for the help.
Edit: To clarify, I think it's the "correct" solution, but I also think that it's more difficult to maintain than my "solution."
But you aren't calibrating the joysticks, your calibrating the victors.
To fix the joystick drift issues, designate a button that, when pressed, makes the current value the new center and, thus, send 127. Offset from center determines offset from 127.
