Go to Post My code mentors once told me, "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." - slavik262 [more]
Unread 24-09-2011, 23:23
Andrew Lawrence
Posts: n/a
Shafts for banebots wheels
We are looking into the 3-7/8" x .8" banebots wheels, and wanted to know if they had any shafts to go with these wheels. I can't find any on the website. We are thinking of using either the hex mount or the key mount. We will also need belts and gears to match the size, but that's aside the point.
Thanks!
Unread 25-09-2011, 06:25
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Shafts for banebots wheels
McMaster always has them, if you need a fast and easy solution:
Hex: http://www.mcmaster.com/#stainless-s...x-rods/=e7p7ha
Round (with key option): http://www.mcmaster.com/#stainless-s...shafts/=e7p8hc
but with speed and ease comes price. Maybe not enough to seem consequential on any one project but it adds up over time, so I'd look around your local area for metal suppliers.
--Ryan
FRC 766, 2015-, Mentor
Unread 25-09-2011, 07:47
jtus jtus is offline
AKA: Just Jack
Rookie Year: 1994
jtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of light
If you use keyed shaft this is what we use.
http://www.mcmaster.com/#keyed-shafts/=e7qan9
saves a lot of work.
but we have switched to hex shaft. That solves all of the broken key problems.
Unread 25-09-2011, 12:02
Andrew Lawrence
Posts: n/a
Thanks!
Unread 25-09-2011, 16:05
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
I stumbled across this while looking for a cheaper alternative to McMasterCarr:
http://www.reidsupply.com/GrpResults...d=10021895&bi=
I dont know if it is reliable or not, but it is nearly 1/3 the price of the axles from McMaster...
Unfortunately they only give you two sizes... 3ft and 6ft, so you will have to find a way to cut it.
We will probably order these for our Banebot wheels.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 25-09-2011, 16:17
Chris is me's Avatar
AKA: Pinecone
You're going to have to cut metal sometime in your robotics team's existence. Might as well learn how to now.
I'd suggest hex.
Unread 25-09-2011, 17:18
Andrew Lawrence
Posts: n/a
Anyone have any experience with this?
Unread 26-09-2011, 09:30
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I don't have any experience with the particular products from Reid Supply, however, keyed shafting is a commonly available item, I know we have a couple places locally that we can get it. Look around for places that deal with "power transmission" or "industrial supply".
I certainly would avoid stainless steel unless there is a compelling reason to need the material properties (and I can't think of one in a FRC robot, at least not until we finally get the long awaited "water game"). It's a lot easier to cut 1018 steel.
Here are a couple other places you can get it besides McMaster:
http://www.fastenal.com/web/search/p...N-gj52ws&Nty=0
http://www1.mscdirect.com/eCommerce/...scrNtk=default
And a Google search for "keyed shafting" will turn up a lot more possibilities.
Personally, I hate keys and much prefer to use hex shafting whenever possible. This hatred goes back 20+ years.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
