Go to Post I got Vista with mine. It's like getting moldy fruitcake for Christmas. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 07-09-2011, 15:21
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
[FTC]: Using Anderson Connectors for wiring.
I found this document via Twiter:
http://www.usfirst.org/sites/default...pole-Guide.pdf
It's a pretty cool description of a different way to connect your motor/servo controllers. And since it's on the FIRST site I assume it's legal.
I just checked out the link to the parts, and they are are suprizingly inexpensive. $11 will get you eveything you need for 5 connector sets. The only real expesne is the crimper if you want a nice one.
One of the additions I'd make to the idea is that you should replace the connector on your charger to be one of these Anderson types as well, and use it to plug into your system to charge the battery.
The problem that we had last year was that the current battery connectors don't seem to be designed for the hundreds of connect/disconnect cycles that we put them through. Eventaully the copper pins loosen up and start glitching on robot-robot impacts. What look like telemetry dropouts are actually power resets on the Samantha module.
The Powerpole connectors have stainless steel springs built into the connectors so they are rated for 10,000 connect cycles. Plus they are rated for 45 Amps.
The bonus is that if this system removes the multiple wires in a screw terminal issue and the need to pull wires to replace a motor controller.
The additional connectors may add a bit of bulk, but if it increases reliability it's worth it. Mine are on order now !!!!
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 07-09-2011, 17:34
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: [FTC]: Using Anderson Connectors for wiring.
In the past it has not been legal to change the connector attached to the battery, I believe, which would be why the document doesn't show this being done.
Nope, I see what you mean. Good idea.
Unread 07-09-2011, 18:02
PhilBot's Avatar
AKA: Phil Malone
Yeah,
It would be great if we could change the battery connection, but even if we can't, using the proposed wiring we could just change the connector on the charger (or even make an adaper cable) and plug in the charger dowsntream from the power switch (using the Anderson connector).
You'd just need to make sure the switch was ON when you went to charge.
The existing battery connector is fine, as long as you don't make it loose from many hundreds of connections.
ps: I do think we should lobby for being able to change the battery connector if we are fine with voiding the warrentee
Phil.
Phil Malone
Unread 08-09-2011, 08:08
Phil,
As much as I like these connectors (we have used them for years on our FRC robots) under 2011 rules they are not legal for FTC. Specifically, they are not official Lego or Tetrix parts and are not on the allowed materials list. While 2011 rules do allow for splicing electrical connections, they specifically call for tape to insulate such connections.
However, if you check my other posts on this subject, you will find that I highly recommend the West Mountain Radio crimp tool. We use these connectors for all FRC motor connections and a variety of other uses on our robots. If FTC rules will allow these in the future, I expect that battery connectors will be required to remain as they are provided from the manufacturer. If for no other reason than to have compatibility between teams.
Unread 08-09-2011, 08:24
PhilBot's Avatar
AKA: Phil Malone
Phil,
Since the 2011/12 rules are yet to be released, I don't know if they are legal or not this year, but it would amaze me if FIRST went to the effort of collecting this information from a team, and placing it on their website if they weren't going to be legal. Plus they (FIRST) are pushing the document on Facebook and Twitter.
Phil.
Phil Malone
Unread 08-09-2011, 09:28
Agreed but stranger things have happened in the past. We will know in a few days.
Unread 10-09-2011, 21:06
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Just a followup now that the FTC rules have been released. Rule R5(c)-26 says:
Anderson 30 Amp PowerPole or similar Crimp style snap plug connectors and butt splice connectors for joining electrical wires are allowed. Power distribution panels may also be used (and is strongly recommended) to make wiring easier.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 19-09-2011, 12:36
Pittwood Pittwood is offline
FTC #2888
Pittwood is an unknown quantity at this point
Hi Phil,
We thought we would try the Anderson 30 Amp connectors. Should we buy the unassembled or the permanently bonded? Also, the FIRST components list recommends a power distribution panel. Do you know what that is?
Thank you.
Ron Pittwood
Coach
FTC 2888
Unread 19-09-2011, 15:27
Ron,
There is/was a power distribution panel for FTC in the past. I have been looking for it but haven't found it yet. It simply was a power terminal that connected the battery to multiple outputs. I believe that is what is referenced.
Unread 19-09-2011, 21:37
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
These PowerPole Splitters look interesting:
www.powerwerx.com/powerpole-power-distribution/ps-8-inline-8-way.html
www.powerwerx.com/powerpole-power-distribution/ps-4-inline-4-way.html
Unread 20-09-2011, 07:49
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Lightbulb Re: [FTC]: Using Anderson Connectors for wiring.
Nice find Michael.
It appears that it is a common bus bar with power coming into any lead and being shared across all others. This is a nice way to put in future options for adding devices later. Start with the 4 bus version and then swap it out for the slightly larger 8 bus version.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 23-09-2011, 15:20
Scott_4140 Scott_4140 is offline
FTC #4140 (Fish in the Boat)
Scott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really niceScott_4140 is just really nice
So, the ruling states the we can use up to 30Amp Anderson Connectors. I can't believe there is anywere near this much current running through an FTC robot. The 15 Amp connectors greatly reduce the bulk of these connectors. The contacts are universal between the 15 and 30 Amp connectors, so you can use the larger 16 gage contacts for the folded over wire and still install them in the 15 Amp connectors.
Does anyone see a reason not to use the 15 Amp connectors?
Unread 23-09-2011, 15:53
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Yes. You risk failing inspection, because they're arguably illegal. (What is "similar"?)
It's at least plausible that FIRST had a technical reason for mandating the higher-current connectors—maybe they were especially (perhaps inordinately) concerned about durability, for example.
And even if it's just a mistake on FIRST's part, ask about it in the Q&A forum before deciding to use the 15 A versions.
Unread 24-09-2011, 20:50
ssi ssi is offline
AKA: David Spangler
FTC #2843 (Under the Son)
ssi will become famous soon enough
Actually, I think you are confused on the differences between the 15 and 30 amp connectors. According to this page:
http://www.powerwerx.com/anderson-po...owerpole-sets/
The 15, 30, and 45 amp connectors share the same housing, the only difference is in the contact.
The reason that FIRST specifies 30 amp connectors is probably because the battery is fused at 20 amps. It would be poor design to use a connector rated for less than the fuse on the circuit.
I hope this helps.
Unread 25-09-2011, 00:09
David, I think your assessment is correct. The safety of the contact is an issue and the 15 amp contact is not the same as the 30 amp contact. The housing is the same for 15, 30 and 45 amp contacts. I also agree with Tristan, only the Q&A can make a firm answer on this point.
