Go to Post I love losing my voice in the name of F.I.R.S.T :) - Athleticgirl389 [more]
Unread 06-12-2002, 23:52
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Exclamation iParts on firstcadlibrary.com
Just a heads up that I've started posting iParts on my website FIRST CAD Library. When you insert one of these models into an assembly, a dialogue box pops up to allow you to customize the part.
This feature requires Inventor 5 or better.
I'd like to get a little feedback over the next couple of weeks if you have an issue or find these usefull.
Thanks
Ed Sparks
MECH TECH FRC-3959
Unread 07-12-2002, 01:22
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
I like it
Though I run the animations team on my team, I would like to compliment you on your great work, I know that I use some of the field parts for my animations, and it saves me a ton of time then modeling it my self.
Keep up the great work and thanks,
Tyler
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 07-12-2002, 21:17
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
When I insert i-sprocket.ipt as is, it works okay.
I tried to change the number of teeth to 48 and received:
[WARNING] Part2: Errors occurred during update <DcKernelRes(213)> [r:\core\Rd\Main\Component.cpp, line 329]
[WARNING] i-Sprocket.ipt: Errors occurred during update <DcKernelRes(213)> [r:\core\Rd\Main\Component.cpp, line 329]
[ERROR] Sprocket Blank: Could not build this Revolution <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 176]
[ERROR] A profile loop could not be repaired after sketch geometry was edited or deleted. Use Edit Feature to reselect the profile. <RdRes(818)> [r:\core\Rd\Main\RdDiagnoses.cpp, line 1771]
[ERROR] Sketch2: Could not build this Sketch <DcKernelRes(205)> [r:\core\Rd\Main\sketch.cpp, line 507]
[WARNING] Coincident constraint to reference geometry that could not be resolved. Use Edit Sketch to delete the reference geometry and rebuild the constraint. <RdRes(369)> [r:\core\Rd\Main\RdDiagnoses.cpp, line 2216]
[ERROR] Tooth Profile: Could not build this Extrusion <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 176]
[ERROR] Cannot cut/intersect an empty part. Use Edit Feature to change the feature definition or Reorder the feature. <RdRes(843)> [r:\core\Rd\Main\Extrusion.cpp, line 2095]
[ERROR] Sketch4: Could not build this Sketch <DcKernelRes(205)> [r:\core\Rd\Main\sketch.cpp, line 507]
[ERROR] Circular Pattern1: Could not build this Circular Pattern <DcKernelRes(205)> [r:\core\Rd\Main\Pattern.cpp, line 2242]
[ERROR] All features involved in the pattern failed to execute; stopping pattern execution. Fix the problems for the input features. <RdRes(836)> [r:\core\Rd\Main\PatternUtil.cpp, line 652]
[ERROR] Sketch3: Could not build this Sketch <DcKernelRes(205)> [r:\core\Rd\Main\sketch.cpp, line 507]
[ERROR] Hub Extrusion: Could not build this Extrusion <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 176]
[ERROR] Shaft Bore: Could not build this Extrusion <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 176]
[ERROR] Sketch5: Could not build this Sketch <DcKernelRes(205)> [r:\core\Rd\Main\sketch.cpp, line 507]
[WARNING] Dimension to reference geometry that could not be resolved. Use Edit Sketch to delete the reference geometry and rebuild the dimension. <RdRes(367)> [r:\core\rd\rddiagnoses.h, line 653]
[ERROR] Keyway: Could not build this Extrusion <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 176]
[ERROR] Chamfer Edges: Could not build this Chamfer <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 176]
[ERROR] null pointer to entity given <Acis(4124)> [r:\core\Mi\helpers.cpp, line 359]
[ERROR] Failed to save factory member <UcRes.dll(846)> [r:\Application\Uc\Request\UCxSetToMemberReq.cpp, line 730]
--Madison--
...down at the Ozdust!
Unread 08-01-2003, 23:30
Exclamation i-Sprocket is fixed
I finally found and fixed the problem with my i-Sprocket. The new version is posted in First CAD Library under the sprockets library.
Thanks M. Krass for the heads up ....
This part is actually an I factory that generates #25 & #35 sprockets with or without hubs and with or without keyways.
Ed Sparks
MECH TECH FRC-3959
Can I reduce the number of similar part files? roknjohn Inventor 2 29-01-2003 21:36
