Go to Post Our strong support is the result of 14 years of very organized "nagging". :) - OZ_341 [more]
Unread 17-09-2011, 14:54
Stonemotmot Stonemotmot is offline
FRC #0486
Stonemotmot is an unknown quantity at this point
How to set up a 3rd (non drive) motor in C++ Windriver
I'm relatively new to programming in C++ and i have a question regarding how to set up a third motor for say arm control. I am using the default Simple Robot Template in windriver. I already understand how to set up tank and arcade drive but as this 3rd motor will only be used for arm control and not driving I'm hesitant to reuse those commands. The biggest problem I am having right now is figuring out how to take a joystick input such as a get-Axis or something like that and send the information to a motor or speed controller. Thanks in advance.
Unread 17-09-2011, 15:08
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Re: How to set up a 3rd (non drive) motor in C++ Windriver
I suggest looking into the Jaguar, Victor, and Relay classes. As for the get-axis stuff, I'm pretty sure the Joystick class has a GetAxis method that returns x, y, or z axis(though many don't have a z-axis), though the translation between joystick and pwm output is up to you.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 18-09-2011, 12:19
FRC #0486
Thanks for the info I'll look into it.
Unread 19-09-2011, 08:13
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
From my fuzzy memory...
Among your member variables:
Jaguar* pMotor;
In the body of your constructor
pMotor = new Jaguar(...); // I don't remember the specific parameters. One will be the slot your sidecar comes out of, one will be the PWM output the motor is connected on
In your operator-control code:
pMotor->Set(0.5); // partial forward. I may have gotten the function name wrong. Check out the .h file for details.
Unread 26-09-2011, 22:17
Tommy.Brown's Avatar
Tommy.Brown Tommy.Brown is offline
Lead Programmer
FRC #1477 (Texas Torque)
Tommy.Brown is an unknown quantity at this point
WPILib will become your greatest friend, it has everything you need to know to program the robot.
FRC Team 1477 - Texas Torque
The Woodlands, Texas
Unread 26-09-2011, 23:51
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
if you're looking to use an axis as your motor control:
1. joystick(whichever joystick you're using).GetRawAxis(#), i can't remember the axis numbers but if you do a print statement, for all the different axis.
2. look into using a encoder or potentiometer (feedback) thus you can use a pid loop. for more info about pid loops, check: http://www.simbotics.org/resources/controls
3. joystick tips, use a limit function to limit the output of the joystick. also a dead band function helps with the problem that most joysticks don't go back to zero often or at all
Unread 27-09-2011, 15:53
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
bool Driver_Station_Joystick::read_joystick (size_t nr, JoyState &Info)
//First weed out numbers not in range
int Number=(int)nr;
Number-=m_StartingPort;
bool ret=false;
nr++; //DOH the number selection is cardinal!
if ((Number>=0) && (Number<m_NoJoysticks))
memset(&Info,0,sizeof(JoyState)); //zero the memory
//The axis selection is also ordinal
Info.lX=m_ds->GetStickAxis(nr,1);
Info.lY=m_ds->GetStickAxis(nr,2);
Info.lZ=m_ds->GetStickAxis(nr,3);
Info.lRx=m_ds->GetStickAxis(nr,4);
Info.lRy=m_ds->GetStickAxis(nr,5);
Info.ButtonBank[0]=m_ds->GetStickButtons(nr);
ret=true;
return ret;
This is the code I use to obtain the Joystick values... The axis are x, y, z position followed by x, y, z rotation (these enumerations match Microsoft's DirectInput sdk), and my info structure is the same as direct input.
Once you get these values you can manipulate them... the range is -1 - 1.0 on the axis ... here are some of my axis params
IsFlipped - Apply a -1 scalar
Multiplier - Apply a scalar
FilterRange - apply a deadzone range
isSquared - square the input (this is used more times than not)
Here is what I do:
if (AnalogEvents)
//Now to use the attributes to tweak the value
//First evaluate dead zone range... if out of range subtract out the offset for no loss in precision
//The /(1.0-filter range) will restore the full range
double Temp=fabs(Value); //take out the sign... put it back in the end
Temp=(Temp>=key.FilterRange) ? Temp-key.FilterRange:0.0;
Temp=key.Multiplier*(Temp/(1.0-key.FilterRange)); //apply scale first then
if (key.isSquared) Temp*=Temp; //square it if it is squared
//Now to restore the sign
Value=(Value<0.0)?-Temp:Temp;
std::vector<std::string>::iterator pos;
for (pos = AnalogEvents->begin(); pos != AnalogEvents->end(); ++pos)
m_controlledEventMap->EventValue_Map[*pos].Fire(key.IsFlipped?-Value:Value);
You may want to ignore the event firing lines except to say that the event value map will do a map (i.e. log-n) search for the events associated with an input and fire them... I do this because it allows me to easily switch axis assignments etc. Ideally the code is more robust if you do not hard wire the controls directly to object that listens for event changes.
Now then in the main I do the following:
void OperatorControl(void)
printf("Starting TeleOp Session\n");
m_Manager.ResetPos(); //This should avoid errors like the arm swinging backwards
m_Manager.GetRobot()->SetUseEncoders(false);
m_Manager.SetAutoPilot(false); //we are driving the robot
double tm = GetTime();
m_Manager.SetSafety(true);
while (IsOperatorControl() && !IsDisabled())
double time=GetTime() - tm;
tm=GetTime();
m_Manager.TimeChange(time);
Wait(0.010);
I make one call to a TimeChange(time) which then dispatches to poll the joystick and fire off the events. The robot class (the class that processes the events) will then call:
void Robot_Control_2011::UpdateVoltage(size_t index,double Voltage)
switch (index)
case FRC_2011_Robot::eArm:
//Note: client code needs to check the levels are correct!
m_ArmMotor.Set(Voltage); //always the same velocity for both!
#ifdef __ShowPotentiometerReadings__
DriverStationLCD * lcd = DriverStationLCD::GetInstance();
lcd->PrintfLine(DriverStationLCD::kUser_Line4, "ArmVolt=%f ", Voltage);
#endif
break;
case FRC_2011_Robot::eRollers:
m_RollerMotor.Set(Voltage);
#ifdef __ShowRollerReadings__
lcd->PrintfLine(DriverStationLCD::kUser_Line4, "RollerVolt=%f ", Voltage);
#endif
break;
Where these are defined as such:
Victor m_1,m_2,m_3,m_4; //explicitly specify victor speed controllers for the robot drive
RobotDrive m_RobotDrive;
Victor m_ArmMotor,m_RollerMotor;
We use victor speed controllers! You'll need to know what you use to get the best reading derivative when the floating point gets translated to integer values.
On a side note: the robot drive we use the constructor that allows you to explicity specify what controllers you want to use since the default case assumes you have Jaguar speed controllers.
Here is a snip of how to do that:
Robot_Control::Robot_Control(bool UseSafety) :
m_1(1),m_2(2),m_3(3),m_4(4),
m_RobotDrive(&m_1,&m_2,&m_3,&m_4),
//m_RobotDrive(1,2,3,4), //default Jaguar instantiation
m_ArmMotor(5),m_RollerMotor(6),m_Compress(5,2),
Note: that for the arm Victor, the contructor use shown here assumes the digital side car is hooked up to slot 4 in the cRio. The first parameter shown indicates which channel on the digital side car that you are using.
I realize this presentation could be over-whelming, so feel free to ask more questions.
Unread 27-09-2011, 19:43
Chexposito's Avatar
AKA: Expo
FRC #1730
not to mention you are not using the resources given to you in the wpi library...
which makes what you did into significantly less code for someone new to programming...
it also makes it a lot easier...
and less time consuming...
which gives you time for the programming autonomous, which has factor for winning matches in FIRST for 4 of the past 5 years...
Unread 27-09-2011, 20:23
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach - FRC Under Development
FRC #6370 (Texas Titans)
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
Chexposito, could you expand on this? Help make us smarter about this statement?
THANKS for your help!
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- Head Coach / Founder - FRC 6370 Texas Titans < FRC and VEX teams under development - VRC 15842a >
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
Unread 27-09-2011, 21:41
Chexposito's Avatar
AKA: Expo
FRC #1730
For example, last year's autonomous included scoring the ubertubes. the points for scoring the ubertubes was enough of an incentive, but the 2x bonus was another incentive. note all teams on Einstein had an autonomous.
In Breakaway, autonomous was not as key, but was useful.
In lunacy, autonomous' purpose was to get away from they human players. if you didn't drive away, you could count on the human player filling your trailer to the top.
In overdrive, you got points for knocking the off the trackballs and driving around the field.
In rack 'n roll the keepers were scored only during autonomous (similar to ubertube) and over-rode any scoring on that peg at any point in the match (always red/blue)
based on the importance of autonomous this previous season, i don't this first will ease up on the scoring involved with this portion. the autonomous usually could make or break matches. and usually the sensors that make autonomous easier usually make driving the robot easier.
Unread 28-09-2011, 14:44
JamesTerm's Avatar
Terminator
AKA: James Killian
What resources are you referring to in particular?
Let us see the significant less code you mention... I've showed my cards... let's see your hand.
We may all learn something from this.
Unread 28-09-2011, 23:34
Chexposito's Avatar
AKA: Expo
FRC #1730
i am referring to the wpi library that is given to all frc teams. it includes code for the joysticks, sensors, and so on. pretty much if you put a sensor on your robot, there is code made and debugged for it. which pretty much leaves you to only have to deal with the code in myrobot.cpp and myrobot.h
Unread 29-09-2011, 00:04
JamesTerm's Avatar
Terminator
AKA: James Killian
Ok, I just wanted to make sure that there wasn't something that I missed. Please look at my code a bit more closely... it is indeed using the WPI library. In fact I have looked through the wpi source... submitted bugs, and am contributing to 2012 wpi libs on the beta team. Whew, there for a moment I thought I missed something. Yes my code was not made to present to a new person, but I wanted to get something out here that is thorough. Plus, it would be good for someone to challenge it to make it better.
Unread 29-09-2011, 09:13
Chexposito's Avatar
AKA: Expo
FRC #1730
i'm just saying your time would be better used during the season using the library... especially if you want students to learn to program. you'll loose all your new people pretty quickly without the use of the library. off season is fine, but if you don't make programming fun for the new people, they won't stay interested when you get to the headache moments. the best thing is to have them just program the myrobot files and look at the wpi library to try to understand how the function works, if they're interested in how the functions. but writing that stuff during the season will leave you with no time and an arm that moves inefficiently by dead reckoning. now as a mentor you can write this stuff yourself in your free time or working on another computer while they're working on the myrobot files. we created our own pid this past season but that was my mentor's doing, this was to make our pid work better for our uses. just some suggestions... this is after all a program for learning and mentoring... you might be surprised the functions some of these students come up with
Unread 29-09-2011, 10:45
JamesTerm's Avatar
Terminator
AKA: James Killian
It is funny that you should bring up PID, this was one of the things I've been wanting to address as well. Check these out:
http://www.termstech.com/articles/Autonomous2.html
http://www.termstech.com/articles/PID_Kalman.html
One thing I regret is that I didn't spend more time writing an article to answer this question that goes more into some of the coding principles like top-down design bottom up implementation, and show a high level design of how the pieces fit together. I still may do this in the future, but there is so much other work I need to tend to (all within the robotics realm).
